cyp sensor
Old Feb 21, 2006 | 09:58 AM
hoopty8211's Avatar
Default cyp sensor
what is it and what color wires run from it
Old Feb 21, 2006 | 10:28 AM
P_Adams's Avatar
Default Re: cyp sensor (hoopty8211)
The CYP sensor detects the position of the No. 1 cylinder as the base for sequential fuel injection to each cylinder, whereas the TDC sensor serves to determine the injection timing for each cylinder. The CKP sensor determines the timing for fuel injection and ignition of each cylinder and also detects engine speed. The TDC sensor is also used to detect engine speed to read out the basic fuel injector duration for different operating conditions.
It's also known as the cam angle sensor.
Most cases mounted in the distributor
P
TEGPOWER44
Jan 13, 2003 04:00 PM
maximedx
Mar 25, 2002 02:51 PM
