94 accord lx, no left highbeam
Old Feb 21, 2006 | 09:30 AM
Hcivic88's Avatar
Default 94 accord lx, no left highbeam
hey guys
i have a 1994 honda accord lx coupe. my daytime running lights dont work and neither does my drivers side high beam. also, the DRL light is lit up on the dash when my lights are not turned on.
i checked the (day light) fuse under the dash, and both headlight fuses under the hood, and everythign seems good, same with the headlight bulbs themselves. i also changed my drl relay underneath the dash(bought a new one from honda) and still nothing... any ideas? thanks
edit: just checked it with the voltmeter.. as soon as i turn my headlights on, the drivers side high beam gets power, but no ground, then when i flick the high beams on, its still getting 12V to it... but there is still no ground.. so its come down to there must be some type of relay or something that controls the ground to the high beam other than the drl relay..
Modified by Hcivic88 at 2:22 PM 2/21/2006
Old Feb 21, 2006 | 03:39 PM
YeuEmMaiMai's Avatar
Default Re: 94 accord lx, no left highbeam (Hcivic88)
cheeck your high beam fuse.
Old Feb 22, 2006 | 07:31 AM
Hcivic88's Avatar
Default Re: 94 accord lx, no left highbeam (YeuEmMaiMai)
where is this high beam fuse located? under the hood all i found was left headlight and right headlight fuse.. i did not see a fuse just for the highbeams, although the sticker on the lid of the fuse box is also in french so that doesnt help any.
Old Feb 22, 2006 | 11:26 AM
kylep's Avatar
ok so i have the same car(94 accord lx coupe) and i have the exact same problem....as in the have the DRL light on and no left high beam... Iv been trying to figure this out aswell and no conclusion as of yet.
Can you guys help us out?
kyle
Old Feb 22, 2006 | 02:25 PM
kylep's Avatar
TTT
Old Feb 22, 2006 | 03:08 PM
Hcivic88's Avatar
Default Re: (kylep)
haha.. really eh.. well atleast i know im not the only one
there must be a relay for the headlights or something though.. ive already tried the drl relay.. im gonna test the drl harness tomorrow to see if that tells me anything
Old Feb 23, 2006 | 05:43 PM
Hcivic88's Avatar
Default Re: (Hcivic88)
nobody? c'mon.. somebody must have had this problem before
Old Feb 23, 2006 | 05:45 PM
fusebox in the engine bay passenger side of car at the strut tower
Old Feb 23, 2006 | 06:00 PM
Hcivic88's Avatar
Default Re: (YeuEmMaiMai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai &raquo;</TD></TR><TR><TD CLASS="quote">fusebox in the engine bay passenger side of car at the strut tower</TD></TR></TABLE>
which fuse is for the highbeam tho? i found the left and right headlight fuses, and they're fine.. but i dont see a fuse for just the highbeams... is the dimmer relay or headlight relay maybe one of the causes?
Old Feb 23, 2006 | 09:11 PM
Dmc1's Avatar
JUst pull every fuse in the box one at a time and check them.If you find a bad one cool! problem solved.But I doubt it.Sounds like a relay to me.
Old Feb 24, 2006 | 02:15 PM
Hcivic88's Avatar
Default Re: (Dmc1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">JUst pull every fuse in the box one at a time and check them.If you find a bad one cool! problem solved.But I doubt it.Sounds like a relay to me.</TD></TR></TABLE>
checked all the fuses, they're definately all good.
Old Feb 24, 2006 | 03:12 PM
Dmc1's Avatar
Try running a temporary jumper wire from the org/white wire on your right side Hi beam.to the left side.Their has to be a short in the line going to your left side hi beam.
And check your dimmer relay the left side HI beam gets its ground from it and recheck fuse #19 it's a 20a fuse.
Their is probably a short in the ground between the right hi beam ground and the left side hi beam,The ground source starts at the dimmer switch and goes to the right side Hi beam first then it goes to the left side Hi beam.
I think if fuse 19 was blown you wouldn't have any positive to the lights.So it's probably not blown like you said.
Modified by Dmc1 at 4:40 PM 2/24/2006
Old Jun 14, 2024 | 04:03 AM
tazim's Avatar
i also have 1994 honda accord with the same problem it has no ground & no 12volts coming to the headlight plug i have been trying for a long time to get it resolve
Alonso Robles
Jun 14, 2017 09:14 AM
Tahir Karamat
Nov 6, 2016 03:53 PM
pr1madona
Honda CR-V & Element
Oct 1, 2016 11:52 AM
AntCrace
Oct 4, 2014 08:17 PM
not-a-stang
Apr 9, 2008 07:50 AM
