What all engine would be a direct swap? 95 GSR
Old Feb 21, 2006 | 08:58 AM
KooK's Avatar
Mustang Sally
Default What all engine would be a direct swap? 95 GSR
Gotta 1995 GSR and I NEED to get this car running. So I'm goina have to swap in a cheap ole engine to get me running around for now.
What all engines are a direct swap? (90-93 Integra engines? B18Bs, B20s?)
Old Feb 21, 2006 | 09:02 AM
four1one
Guest
Posts: n/a
Default Re: What all engine would be a direct swap? 95 GSR (KooK)
Direct swap would be any B series motor 92-95... it will just drop in no wiring needed... but you will probably have to change the ecu.
Old Feb 21, 2006 | 09:06 AM
KooK's Avatar
Mustang Sally
Default Re: What all engine would be a direct swap? 95 GSR (four1one)
So wiring configurations for a 91 are different? (I've got somebody trying to sell me a 91 LS engine)
Old Feb 21, 2006 | 09:12 AM
four1one
Guest
Posts: n/a
yes they are obd0... but you could still get it to work... the check engine would just be on
edit: i used my 5 post for the day... but i dont think you can use uberdata to make it obd0
Old Feb 21, 2006 | 09:13 AM
KooK's Avatar
Mustang Sally
Could I possibly reprogram (Uberdata) my P72 to run with an OBD0 engine?
Old Feb 21, 2006 | 09:17 AM
LordAphotic's Avatar
its not really the programin thats the problem. the plugs that plug into the engine are usually different from obd0-obd2b
Old Feb 21, 2006 | 09:26 AM
loudassVTEC's Avatar
no. Just use the dizzy that is on your GSR now. You'll definitely have to change your ECU. Or if you have Uberdata, just run the ECU you have now, with a LS map programmed on it. You can't reprogram to run an OBD-0 motor. You'll have to run an OBD-1 dizzy, and your OBD-1 o2 sensor.
hrdknoxx
Jun 14, 2007 10:38 PM
Rayboogie
Apr 28, 2004 05:48 AM
MugenFan
Nov 14, 2003 10:25 AM
JDM CRX
Apr 5, 2003 06:19 AM
