hooking up amp & sub to factory, is it possible?
Old Feb 21, 2006 | 08:28 AM
bl024292's Avatar
Default hooking up amp & sub to factory, is it possible?
i want to know if its possible, and if so wha twould i need to complete the job. i have an amp, and 2 subs enclosed. i know i'll need wiring but is it even capable of working
Old Feb 21, 2006 | 08:45 AM
shyboy817's Avatar
Yes you'll need a RCA Line Output Converter. Which can be found at your local audio store.
Old Feb 21, 2006 | 10:00 AM
suspendedHatch's Avatar
Default Re: (shyboy817)
aka high low converter. you wire it to your rear speaker wires.
Old Feb 21, 2006 | 04:32 PM
8520's Avatar
Default Re: (suspendedHatch)
Hopefully your amp has a bass ****
Old Feb 23, 2006 | 05:49 AM
VisualAutoMotoring's Avatar
Default Re: (got_no_sol)
High to Low Level Converter. Takes a speaker level signal and converts it to rca signal. You can either trace it from the back of the headunit ( most commonly done or from the rear speakers on your car.
This will not provide the cleanest sound but gets the job done.
Old Feb 23, 2006 | 07:47 AM
Default Re: (Hybrid-Performance.com)
Isn't that exactly what I said?
Keep getting your post count up.
Old Feb 23, 2006 | 10:39 AM
fcm's Avatar
fcm
Old Fart
Default Re: hooking up amp & sub to factory, is it possible? (bl024292)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bl024292 &raquo;</TD></TR><TR><TD CLASS="quote">i want to know if its possible, and if so wha twould i need to complete the job. i have an amp, and 2 subs enclosed. i know i'll need wiring but is it even capable of working </TD></TR></TABLE> You could also just get an amp that has speaker level, [high level] inputs.
Although, as has been mentioned, SQ is not that good doing it that way, [either built into amp or off board "LOC"] for a sub it's no biggie.
The alternatives can be expensive, obviously the best thing to do is replace the HU with an aftermarket HU with a sub out, next would be to have a tech install a RCA pig tail, [rca outputs] on the oem HU, [he will connect them up the the preamp stage of the HU, and if you want to keep the oem HU but you want to amp everything then something like this is needed to get good sound... http://mobile.jlaudio.com/prod...id=94 94
necraglio
Audio / Security / Video
Apr 29, 2008 06:49 AM
civicgsr93
Oct 19, 2004 05:45 PM
shyboy817
Aug 12, 2004 11:30 PM
FatJoe
Oct 5, 2003 10:12 AM
SSBP DC2
Apr 18, 2003 12:22 AM
