Will a HID kit for an Accord fit my Integra?
Old Feb 21, 2006 | 06:57 AM
scartail's Avatar
Default Will a HID kit for an Accord fit my Integra?
The kit came out of a 96 Accord. I have a 98 RS. I want to check before I get them. My friend is selling me his for a decent price. Thanks.
Old Feb 21, 2006 | 09:12 AM
suken19's Avatar
Default Re: Will a HID kit for an Accord fit my Integra? (scartail)
I think that if the bulb is 9006, then it should fit. All it really matters if the bulb fits our headlight and integra use 9006 bulb. hope this help! BTW, what kevin rating is it on the bulb? also, how long have it been used? I used to have a kit too but one of the ballast died out on me in 18 months and it was hard to find a replacement for it.
scartail's Avatar
Cool. Thanks.
Old Mar 4, 2006 | 08:53 AM
scartail's Avatar
Default Re: (scartail)
Mild disappointment... so far...
I got the kit. Plug and play. Flick the swith on, nothing. So I connect them directly to the battery and it works. So, I thought I blew a fuse or something, but that wasn't it. I threw my old hallogens back in and they work.
Anyone have any ideas on why they will not work? I measured the voltage from the oem light harnesses, and the voltage is where it is supposed to be. The odd think is I measure a negative 12v. I check my digital mulitmeter and all, thought it was something I did.
Anyone have any suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suken19 &raquo;</TD></TR><TR><TD CLASS="quote">I think that if the bulb is 9006, then it should fit. All it really matters if the bulb fits our headlight and integra use 9006 bulb. hope this help! BTW, what kevin rating is it on the bulb? also, how long have it been used? I used to have a kit too but one of the ballast died out on me in 18 months and it was hard to find a replacement for it.</TD></TR></TABLE>
How do I know what rating it is? I dont' see any markings on the ballasts that state such.
Old Mar 5, 2006 | 02:04 AM
nsxnext's Avatar
What kit is it? Are the connectors for the HID ballest correct with the owm connectors?
Old Mar 5, 2006 | 02:25 AM
db8geezer's Avatar
Default Re: (nsxnext)
i had the same problem.....on the OEM wire on the integra you have to change the positive side to the negative and the negative to the positive....what i did was just cut the wires and switched sides and connected it and everything worked fine
Old Mar 10, 2006 | 05:28 PM
scartail's Avatar
Default Re: (db8geezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by db8geezer &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem.....on the OEM wire on the integra you have to change the positive side to the negative and the negative to the positive....what i did was just cut the wires and switched sides and connected it and everything worked fine</TD></TR></TABLE>
That's pretty much what I ended up doing. But it worries me that the OEM lines are like that.
lambertincorp
Lighting
Dec 15, 2007 02:15 PM
AlienKrOZ
Nov 7, 2006 06:37 PM
maui-built
Oct 14, 2005 09:47 AM
aaaallll04
Jul 27, 2003 04:54 PM
dank9513
Dec 9, 2002 04:33 PM
