......d & b series power steering pumps.... (which are interchangeable ? ?)
Old Feb 21, 2006 | 05:52 AM
Charlie Moua's Avatar
Default ......d & b series power steering pumps.... (which are interchangeable ? ?)
I have a 1995 civic LX with stock motor.
My power steering pump is making a lot of noise and has fluids coming out of it.
I think I might need a new one.
My question:
1) Are all D series power steering pumps interchangable?
2) I got a free one but I'm not sure if it's off a EG or EK d series #P02653238Q
Modified by Charlie Moua at 12:00 AM 2/22/2006
Old Feb 21, 2006 | 06:04 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: ......d & b series power steering pumps.... (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">2) My friend has a jdm b16a2 PS pump..... can i use that?
Cause he said he used his 1995 civic ex PS pump & it bolted onto the b16 bracket.</TD></TR></TABLE>
Is the hose that leads to the pump the same? They may not be and that may be the reason he retained the stock PS pump instead of using the one that came with the motor. I'm not sure, it's just a thought.
Old Feb 21, 2006 | 07:36 AM
Default Re: ......d & b series power steering pumps.... (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
Is the hose that leads to the pump the same? They may not be and that may be the reason he retained the stock PS pump instead of using the one that came with the motor. I'm not sure, it's just a thought.</TD></TR></TABLE>
well he keep the stock eg d16z6 PS pump because the PS line from the B16a2 swap was cut.
thats what he told me.
But i think the fitting should be the same though...
Old Feb 21, 2006 | 07:54 AM
fmrprojects's Avatar
it wont work, you can only use the d series 1. u can use the b series if you doing a b series swap
Old Feb 21, 2006 | 08:01 AM
Default Re: ......d & b series power steering pumps.... (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">it wont work, you can only use the d series 1. u can use the b series if you doing a b series swap</TD></TR></TABLE>
thanks....
ok my buddy has a PS pump off his 198 civic DX hb stock d16 motor... will that work & be simple bolt on?
Old Feb 21, 2006 | 09:00 PM
gemballla
Jun 4, 2010 01:49 PM
SpeedDreamz.com
Mar 12, 2008 05:51 PM
thermal
Welding / Fabrication
Dec 14, 2005 02:16 AM
93CharcoalHatch
Sep 5, 2005 07:17 AM
93CharcoalHatch
Sep 5, 2005 07:06 AM
