Brake Switch
Old Feb 21, 2006 | 05:32 AM
TealCivic93's Avatar
Default Brake Switch
I searched but just don't know where it is located. I have a 1990 Civic Si. Thanks.
Also how much is it to replace it? Can I do it myself?
Old Feb 21, 2006 | 05:33 AM
crx_88_si's Avatar
follow the brake pedal all the way up to where u see wires
Old Feb 21, 2006 | 05:39 AM
wood's Avatar
Default Re: (crx_88_si)
Old Feb 21, 2006 | 06:43 AM
thanks? do i have to remove any interior parta to get to it?
btw are the brake lights on the same fuse as the night time lights? blinkers? headlights? just making sure its the brake switch and not the fuse.
Old Feb 21, 2006 | 09:22 AM
jdeemseerx's Avatar
no the brake lights are on the same fuse as the horn.. make sure your horn works..what are they doin stayin on at all times? or just not comin on at all?
Old Feb 21, 2006 | 12:27 PM
Default Re: (jdeemseerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">no the brake lights are on the same fuse as the horn.. make sure your horn works..what are they doin stayin on at all times? or just not comin on at all?</TD></TR></TABLE>
my horn stopped working a few months ago and now the brake lights don't work at all. I know I could check the fuse box, but i don't have a legend in the fuse box anymore to know which is which. What I dould do it take a picture, and maybe someone could tell me which is the brake light/horn fuse.
Thanks
Old Feb 21, 2006 | 12:30 PM
.Manny.'s Avatar
Touching My Member
just check all of them, replace any bad ones
Old Feb 21, 2006 | 07:33 PM
Default Re: (90_EF_Si)
they may sound stupid, but how do I know if a fuse is bad? :S
Old Feb 21, 2006 | 07:48 PM
Targa250R's Avatar
be professional
Default Re: (TealCivic93)
This is a blade fuse. See the element inside, in the shape of an upside-down "U"?
This is what a broken element will look like in a blown fuse:
Hairline break, hard to see:
You get the idea. If the fuse is blown, make sure to replace it with another fuse of the same amperage rating (which is the number printed on the top of the fuse). If the fuse instantly blows again, you have a problem with the circuit somewhere.
Modified by Targa250R at 12:02 AM 2/22/2006
Old Feb 22, 2006 | 05:07 AM
Default Re: (Targa250R)
ok thanks for your help.
Old Feb 22, 2006 | 05:23 AM
crx_88_si's Avatar
or you could use a multimeter and do a continuity test between the two prongs of the fuse
Old Feb 23, 2006 | 11:23 PM
is the brake switch hard to change?
Old Feb 24, 2006 | 08:51 PM
jdeemseerx's Avatar
no its easy..reach up unplug the connector, turn the switch and it comes right out..
Old Feb 24, 2006 | 10:10 PM
Max Kling's Avatar
Default Re: Brake Switch (TealCivic93)
Old Feb 25, 2006 | 01:57 PM
ok thanks. ill check it out as soon as the weather is nice over here.
Type-Spaz
Oct 2, 2011 04:44 PM
ATLHONDA
Mar 22, 2010 04:34 AM
PinoyEJ6
Oct 15, 2007 09:21 PM
afmoose7
Apr 15, 2006 05:07 PM
Nocturnal
Sep 24, 2005 12:23 PM
