Running wires from door to car. What route ?
Old Feb 21, 2006 | 01:13 AM
BrainzIRL's Avatar
Default Running wires from door to car. What route ?
I have an EG3 and iam fitting keyless entry, i have all the actuators set up but when i have to run the wires from the door to the car i have no possible root, other ppl have used the rubber gromet from the door and then to the car.
Only thing is from the door to the car is a socket fitting and wont let any other cables through with it. The only hole in the door is the drain holes at the bottom .
Any help appreciated
Brainz
Old Feb 21, 2006 | 02:37 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
you can go thru the factory scoket. look for the empty space and drill a small hole big enough for the wire to fit thru.
Old Feb 21, 2006 | 07:56 AM
suspendedHatch's Avatar
Default Re: Running wires from door to car. What route ? (BrainzIRL)
On an EG it's pretty easy, no drilling. On an EK I actually just take the doors off because it's faster and better. In some cases I'll drill new holes and put a rubber grommet in, then wrap the wires with heat shrink or split loom and black tape. Especially if it's actuators and speaker wire for components.
Old Feb 21, 2006 | 11:32 AM
BrainzIRL's Avatar
Default Re: Running wires from door to car. What route ? (suspendedHatch)
I followed this guide :
https://honda-tech.com/zerothread?id=749123
but where it has the rubber gromet and then some wires in the middle, i have a gromet which protects a socket fitted with all the wires that need to connect to the door.
I think the only option is to drill a hole in the door and then to the car. But if someone has any other ideas iam open.
Thanks
Brainz
Old Feb 23, 2006 | 12:20 PM
BrainzIRL's Avatar
anyone got any other ideas ???
Old Feb 23, 2006 | 01:20 PM
fcm's Avatar
fcm
Old Fart
If you look closely at the plugs you will see two spots just outside of the pins that can be drilled out on both plugs, [door side and car side plugs] that will give you enough room the run 16ga wire through easily, I have run not only a 16ga speaker wire but 2 18ga wires for door locks into the door, and all the wires are inside the boot, no "punching holes" in the grommets 94
dweston
12
Mar 19, 2013 03:27 AM
pez1
Apr 11, 2006 09:22 AM
nontent
May 15, 2004 07:34 PM
tfalconier
Apr 10, 2004 06:45 PM
MilanoRex
May 19, 2002 08:53 PM
