Cam gears
Old Feb 20, 2006 | 10:30 PM
kizilla831's Avatar
Default Cam gears
I have a 01 Prelude Type Sh. It has Dc 4-2-1 headers, qtp Electronic Open Headers Switch, AEm Cold air intake, pulleys, new Skunk 2 valves.. WEll yes My question is about the cam gears, when i bearly got the car i looked at the cam gears they are aerospeeds.. and they werent set to 0 they were set to -2 ... and the idle was perfect .. and Im pretty Sure the rest of internals are stock.. shoudnt it be idling wrong??... SHould i set it back to 0..
Old Feb 21, 2006 | 08:19 AM
md23vtec's Avatar
Default Re: Cam gears (kizilla831)
Why would it idle wrong?
Old Feb 21, 2006 | 11:24 AM
kizilla831's Avatar
Default Re: Cam gears (md23vtec)
Well i am asking.. BEcause i have stock Cams and stock Valves.. and shoudnt the Cam gears be set to 0.. (in the mIddle)
Old Feb 21, 2006 | 12:40 PM
championshipwhite93si's Avatar
nope its fine. all they are doing is allowing your cams to come on a little later and moving your powerband more toward top end. its ok to run them there but i would recommend getting tuned on the dyno. some cars respond better to different settings. and btw ddnt you say earliar you had new skunk2 valves?
10K RPM
10
Apr 13, 2012 06:18 AM
dc2_916
May 27, 2009 07:49 AM
preludepower01
Jul 28, 2007 07:39 AM
TrueUntilDeath.com
Jul 17, 2004 10:53 AM
mattL
May 1, 2002 11:15 AM
