13" steelies to 15" rota's....
Old Mar 28, 2002 | 05:55 AM
*Boostwerks*'s Avatar
Default 13" steelies to 15" rota's....
I would think that putting larger wheels on even with low pro tires will cause the ride height to slightly increase.
Is this true?
Ayone have before and after pics?
I would be going from a 175/70/13 to a 205/50/15
Thanks for any input
Old Mar 28, 2002 | 07:41 AM
B16CRX's Avatar
Default Re: 13" steelies to 15" rota's.... (Bryson)
Depends on the tires. If the overall diameter is the same, then ride height will stay the same. It is hard to keep it exactly the same though, so when you change wheels the ride height can slightly increase or decrease.
Back when I had 17"s they made the car sit just a little higher, maybe a 1/4". But thankfully I came to my senses and got 15"s. They are almost exactly the same as the steelies. A little more wheel gap than the 17"s, but much better for performance.
Old Mar 28, 2002 | 08:17 AM
Default Re: 13" steelies to 15" rota's.... (B16CRX)
most likely Azenis, or Kumho, but
You did not notice ANY increase in height?
I just would like to know If I need to lower it any more.
I just know that any little increase In height I will notice.
Old Mar 28, 2002 | 08:29 AM
wronghand's Avatar
Keep in mine that these figures are a little rough. They are based on 1 inch = 2.52cm. These are the calculated diameters of each size tire. Also keep in mind actual measurements will vary from brand to brand.
Stock Si - 185/60/14 22.81 inches
Stock DX - 175/70/13 22.72 inches
Stock HF - 165/70/13 22.17 inches
15 inch - 205/50/15 23.13 inches
15 inch - 195/50/15 22.74 inches
Hope this helps.
Edit - That was a typo the 195/55/50 would be 23.51 inches.
[Modified by wronghand, 12:52 PM 3/28/2002]
[Modified by wronghand, 1:24 PM 3/28/2002]
Old Mar 28, 2002 | 08:43 AM
Default Re: 13" steelies to 15" rota's.... (wronghand)
195/55 would be SMALLER than 205/50's???
That's odd.
so what would 195/50 be?
Thanks a lot man.
[Modified by Bryson, 9:44 AM 3/28/2002]
Old Mar 28, 2002 | 09:06 AM
Smoothy's Avatar
No, the ride height is not the same. Doing the math, my wheel diameter is extremely close to stock, but it rides much higher.
The side walls won't sink as much with lower profile tires. That's the only explanation I can think of.
Old Mar 28, 2002 | 09:09 AM
CWBETB's Avatar
I just put on some 195/55/15's on my hatch and compared to the 205/40/16's I have almost no wheel gap. The car sits a bit higher off the ground but looks semi slammed do to the larger wheel/tire
Old Mar 28, 2002 | 09:11 AM
02WRX's Avatar
I noticed a change in ride height when I changed from 195/60/14's to 205/45/16's...
But, if you really want to figure it out the easy way, check out these sites!
http://www.powerdog.com/tiresize.cgi
http://www.mr2.com/FORMS/tire.html
Eric
Old Mar 28, 2002 | 09:20 AM
wronghand's Avatar
Default Re: 13" steelies to 15" rota's.... (90CivicEX)
There appears to be a problem with my calculation. Sorry guys I will correct the above numbers as soon as I find the problem.
Edit- Just figured it out. I had a * where I needed a /.
Edit2- They have been corrected. Damn Excel!
[Modified by wronghand, 1:23 PM 3/28/2002]
[Modified by wronghand, 1:25 PM 3/28/2002]
Old Mar 28, 2002 | 09:30 AM
Default Re: 13" steelies to 15" rota's.... (superfastCRX)
that's the problem I'm seeing.
Everyone just gives me these diameter calculators, but that does NOT calculate the "squish" of the tire.
the calculators are not a very good way of determining how much "higher" the car will be raised.
I keep getting mixed results with people's explinations.
I'm looking for people to tell me what size they had before and after, and if they noticed a change in height. If you did notice a change HOW MUCH roughly DO YOU THINK it was raised?
Also for clarity, assume the tires are inflated to the reccomended amount.
thanks
Old Mar 28, 2002 | 09:37 AM
wronghand's Avatar
There are going to be a lot of different thing that can vary the amount of "squish" in the tire. Someone who has a gutted CRX and is running higher performance tires will not have the same amount of "squish" as someone who has full interior, a tool set and 3000 watts of stero equipment on non performance tires. How much difference are we really talking? As long as you stay within the recommended sizes the difference should be minimal. Is a quarter of an inch really going to make a difference?
Old Mar 28, 2002 | 09:41 AM
no not really, but I have not heard any REAL quotes of how far it is raised.
I have heard people that it raised it up "pretty high"
yeah OK, that tells me something
I know there are going to be many variables, but I'm just LOOKING for people who have noticed this.
Old Mar 28, 2002 | 06:24 PM
02WRX's Avatar
Well, I noticed the difference, including being able to scrape over a few more speed bumps after I changed wheels & tires, so it had to be at least 1/4 - 1/2 inch or so. I've since raised my coilovers up to a more reasonable level, so I only drove it for a week or twom but I could notice the difference.
Eric
Oh... I just realized I have some before/after pics!
Before:
After:
[Modified by 90CivicEX, 3:27 AM 3/29/2002]
wudini
Sep 15, 2007 10:53 AM
Seedc2
Feb 27, 2003 02:43 PM
Philbert
Feb 26, 2002 01:11 PM
YipMan_Style
Feb 20, 2002 11:32 AM
COREY ITR#625
Sep 29, 2001 02:26 AM
