still burnin
Ok the scenario is that I had an h23a1 engine that I swapped out because it was going through oil like every week and would smoke, but had about 170,000 miles on it. I replaced it soon thereafter with a jdm h23a hopping to solve the problem. I ordered the engine which runs great, but without any external parts such as intake manifold, headers, etc. Is it possible that maybe I could be burnin oil because of the old externals maybe the intake manifold? Should I be burnin through oil still?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x »</TD></TR><TR><TD CLASS="quote">no, your old intake manifold, and header and that **** wont make you leak oil</TD></TR></TABLE>
Im not leaking any oil whatsoever its just burnin. How much is it for a compression and leakdown test or can I do it myself?
if you had really bad rings and seals in the old motor I suppose you could have oil in your exhaust/ cat.
So you might have to replace the cat before you get all the oil out. This is just a thought on the situation.
or the new h23 is burning oil too.
either way it sucks.
Its a jdm h23a as it says on the block, but it is not the h23a vtec engine that you are thinking about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz »</TD></TR><TR><TD CLASS="quote">Your JDM H23a is the vtec motor out of the accord wagon, right(Blue Top)? Must because, Japan had the Dohc F22B not a H23a....
And if you do have a JDM H23A, how you like ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_outlaw_x »</TD></TR><TR><TD CLASS="quote">if you want to drop by my house i can take a look at it for you</TD></TR></TABLE>
That'd be cool I'll hit you up.
SIR_APPROVED
Feb 22, 2010 10:21 PM
