cheapest route with spec b's?
whats the most basic route to get 190whp+ with spec b's? im not really interested in a vafc. was wondering if i could just slap them in and use cam gears with them? maybe some retainers/springs and a chipped ecu?
I have no idea why y'all scream "high compression" when Toda B's are mentioned. Sure, you'll get more power, but with good tuning, 185whp is well within reach, with V-AFC, good header, intake and exhaust. Besides, I didn't buy Spec B's for peak power, I bought them for (all together now) BIG FAT MIDRANGE!
Of course, no one believes my motor is still alive running stock valvetrain for 6k miles
[edit] Oh yeah, and cam gears, too. [/edit]
[Modified by itr009, 10:02 AM 3/28/2002]
You need to use something for fuel tuning. Custom chipped ECU maybe, at the very least. 190+ = good engine management and kick-*** tuning.
I would NEVER do Spec B's again without bumping compression. Yes, you'll see gains, but not enough to justify the amount of money spent.
Jason-
who'll be shooting for 200+ whp with the project
Jason-
i always beleive that you get what you pay for.
To a certain degree..... valve springs offer peace of mind as well.....
I've seen anywhere from 175-190 on spec b's or spec c's and stock compression.....
But you really can't get around the fact that NA for these cars is $100 per whp.
Jason-
Jason-
Bah! You big baby
I guess I have the "budget" B set-up:
$275 for V-AFC
$425 for JDM header
$200 for AEM
$50+30 for cat
$200 for Toda gears
$800 for Toda cams
$40 dyno time
STOCK cat-back. STOCK injectors. STOCK valvetrain. STOCK ecu. Built up over the course of 18 months.
But I agree - if I started out saying "I'm going to build a motor for B's" instead of a friend saying "here, buy my B's and I'll throw them in tomorrow" I would go all out - compression, standalone, etc.
Pat, who seems to recall being dead-even with Garth on third-gear pulls
Jason-
who promises to thoroughly apply a smackdown to Pat once the project has been completed
BRING IT!!
I'll throw a 150-shot on Da Gun and fuggin' roast your ***!!! Then I'll fuggin' run over your hatchcrap in the Scout!
All kinds of smackdown for the eight seconds the motor holds together
mine was semi cheap
Comptech Icebox
DC JDM - - -Have since switched to Toda Header
Ported and polished head
2.5 exhaust
Toda Spec B's
AEM cam gears
Portflow /type r valvetrain
VAFC
thats vs stock with a VAFC
Comptech Icebox
2.5 exhaust
Toda Spec B's
AEM cam gears
VAFC
Well, I would think around $2500 for everything. Dyno tunning is not cheap, unless you find some one who has a program sheet to go by for less dyno time.
You'll be happy....
"spend money one time to have it done correctly is how I look at it."
You'll be happy....
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
well, i'm not sure about that. i gained over 40hp at 8,000 rpm with spec b's and springs, drop in. stock injectors, stock throttle body, stock bottom + spec b's and springs = 194hp.
$275 for V-AFC
$425 for JDM header
$200 for AEM
$50+30 for cat
$200 for Toda gears
$800 for Toda cams
$40 dyno time
$275 for V-AFC
$425 for JDM header
$200 for AEM
$50+30 for cat
$200 for Toda gears
$800 for Toda cams
$40 dyno time
My R made 193 to the wheels last season, with 134 ft/lbs or torque. Stock bottom end, stock head, with spec B's. It was enough to for me to tag 12's in a DC2R, at 104+mph.
If you're interested, I can Email you the specs and settings of all my stuff (cam gear, fuel pressure and VAFC settings).
+40whp at 8k with Bs is extremely difficult to believe, especially with stock compression...
cheap route = cheap results in most cases. I would just be patient for another month or so and save $$$ for all the necessary tools. Maybe you can fine tune it with cam-gears and FPR, but why not do it right the first time? dyno time is very expensive to say the least.
GoodFella
Jul 29, 2002 04:12 PM
Drinker
