OBD1 Ecu....
Hey folks i'm new here..
I have a 97 Accord SiR-T from Japan, these cars come with the OBD2 ecu, but i have an OBD1 P13 which i am going to put in. Ofcourse this ecu is from a H22a Prelude (Stock Prelude Map), my question is will it work with my engine? (F20B DOHC VTEC) I also have the OBD2-OBD1 conversion harness, any help will b much appreciated
plez state any comments or errors i may have
Thanks
Thanks
use a little common sense here.... honda designed the h22 ecu to control the h22 motor. get an ecu for your motor or get a chippable ecu and get a rom for your motor. either way, you need a computer to control YOUR motor, not a different one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superorb »</TD></TR><TR><TD CLASS="quote">use a little common sense here.... honda designed the h22 ecu to control the h22 motor. get an ecu for your motor or get a chippable ecu and get a rom for your motor. either way, you need a computer to control YOUR motor, not a different one.</TD></TR></TABLE>
theres no need 4 u to try and b a smartass, i have common sense BTW.....i am asking about this ecu because i have heard that it can b done but may have some issues, i wont b using using the ecu for long anyway, just temperarly, so unless u can help me by answering my question then i would suggest u not answer this thread.
becuz my old ecu is no gud anymore, circuit board is screwed. so i bought an H22 ecu from a friend, the maps are similar so i got the impression it should work, i have heard of it being used on several F20B's but wanted to get other opinions, advice and so on from folks on this site.
