ITR rear sway bar squeaks?
Old Mar 28, 2002 | 05:37 AM
BSQ's Avatar
BSQ
Default Re: ITR rear sway bar squeaks? (98GeeYes-Are)
Some people choose to use the Prothane polyurethane bushings and bushing brackets, instead of the Type-R swaybar bushings and bushing brackets. Squeaking is very common with polyurethane bushings and they require periodic lubrication with special lubrication to prevent squeaking.
If you use the actual Type-R swaybar bushings and bushing brackets (the ones listed on my website), you will not have a problem with squeaking.
Old Mar 28, 2002 | 05:16 PM
98GeeYes-Are's Avatar
Default ITR rear sway bar squeaks?
Is this common? How can it be fixed? I'm planning to install one soon
Old Mar 28, 2002 | 07:09 PM
Erik_Pb_Foot's Avatar
New User
Not all that common if installed properly. It can be fixed with some pitheum grease though. Just a little on the bushing against the bar will get rid of it.
-Erik
phil_lt1
Nov 8, 2009 08:33 PM
CALC!_JUST_du_IT!
Suspension & Brakes
Aug 28, 2007 12:27 PM
johnclaunch
May 26, 2007 12:29 AM
FormulaGSR
Jul 30, 2004 06:40 AM
mingchi69
Sep 20, 2003 08:44 AM
