wheel offsets???
Old Feb 20, 2006 | 03:54 PM
808EK4's Avatar
Default wheel offsets???
I was thinking of buying a set of racing hart type c's on memoryfab.com. The specs of the wheels are 16x7 with a +38 offset and I 'm wondering if I will run into trouble with the offsets of the rims? Will it rub on the fender or will it clear the control arms???Does anyone have any experience with this type or knowledge of this offset of rim for a honda civic. The car is at stock height right now if that helps out.
Old Feb 20, 2006 | 04:00 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: wheel offsets??? (808EK4)
It depends in part on the size of the tire, which you didn't mention. The proper size tire for 16" wheels on your car is 205/45-16; with the proper offset, that size tire should work without rubbing. However, others will have to tell you what the proper offset is.
Old Feb 20, 2006 | 08:42 PM
808EK4's Avatar
I'll probably run that same tires that nsxtasy suggested. Will I run into problems if I lower the car with the wheel and tire package that I have listed?
Old Feb 20, 2006 | 09:04 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (808EK4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808EK4 &raquo;</TD></TR><TR><TD CLASS="quote">Will I run into problems if I lower the car with the wheel and tire package that I have listed?</TD></TR></TABLE>
You don't say anything about the tires. You only described the wheels.
pxlds
Aug 25, 2014 09:24 PM
ProricanEF
Feb 1, 2011 09:58 AM
Fafsa Racing
Nov 30, 2007 06:52 PM
ezol
Jan 24, 2007 02:18 PM
pyitrboy
Jan 10, 2007 05:11 PM
