Im all ears!!! I need bigger slicks!!! Which ones?????
Old Feb 20, 2006 | 03:49 PM
lscrx8.5's Avatar
Default Im all ears!!! I need bigger slicks!!! Which ones?????
Hey dudes I need some help figuring out which slick/wheel setup I should advance to cause last year my MT 20-8.00-14 slicks on steelies were not doing there job!!! I have us b16 pistons in my 95 ls 11.7-1 comp crower 404s and a b16 tranny in my 90 ef hatch. Im leaning towards maybe the 22-8.00-13" slicks from MH but I am not sure, will 13" steelies wear 8" wide slicks and will 22" diameter be a big difference from my 20" diameter MTs cause I have to run like 14 psi in my setup now and everyone at the track is like man you got a flat cause it looks like Im riding on the rim, and even with that low of pressure the bitches spin and its not cause bad track conditions or lack of heating up the slicks. Thanks for any informative suggestions guys!!!!!
Old Feb 20, 2006 | 04:28 PM
onlinehost's Avatar
Default Re: Im all ears!!! I need bigger slicks!!! Which ones????? (lscrx8.5)
i dont know about that 14 psi man i run 6psi in with my setup but i think youll be happy with the 22's and buy an aftermarket wheel for them because the steelies are not wide enough thats why you spin you need a wider contact patch as for tire brand m&h all the way he is a member on here so i am sure he will chime in
Old Feb 20, 2006 | 04:41 PM
lscrx8.5's Avatar
Default Re: Im all ears!!! I need bigger slicks!!! Which ones????? (onlinehost)
Thans man!!! anyone else?? If the 13" steelie is not wide enough then what would be a good wheel to use, something not to expensive on a budget!!!!
Old Feb 20, 2006 | 05:15 PM
xtrafastcivic's Avatar
invest in some real drag wheels.... and 22's would be perfect
Old Feb 20, 2006 | 05:34 PM
onlinehost's Avatar
Default Re: Im all ears!!! I need bigger slicks!!! Which ones????? (XtraFastCRX)
i vote lenso wheels they would be perfect for you
Old Feb 20, 2006 | 07:25 PM
lscrx8.5's Avatar
Thanks man I looked up the lenso vpds, man only 9lbs your right those would be perfect for me anyone know where to find a good deal on two of these????
Old Feb 20, 2006 | 08:22 PM
Soda Popinski's Avatar
https://honda-tech.com/zerothread?id=1515356
Go there and contact expospeed. They are making lenso skinnies soon! Regardless though, they could hook u up with a M&H+Lenso Combo. I say go with 22inchx8x13s. It should be good for your setup.
Old Feb 21, 2006 | 02:26 AM
ExospeedAMcrx's Avatar
Just like what everyone said, the 22x8x13 is the perfect size for what you have.
You are probably making in the range of 160-180HP so that size would be just right. The 22x8x13 is actually the most common size too and can be used in setups making about 220-230hp and as low as 125-130hp.
We have slicks and the VPD wheels ready to go. We mount them, balance, with metal valve stems so when it gets to your door, all you have to do is put in the right tire pressure and you're set.
https://honda-tech.com/zerothread?id=1513424
Here's the slick and wheel deal we are doing right now.
Thanks matador for the link.
Old Feb 21, 2006 | 02:34 AM
Default Re: (exospeedAMcrx)
Here's a pic a few years ago, one of my friends with the VPD on 22x8x13.
Another pic of the 22x8x13 on Wicked Racing's EK
Old Feb 21, 2006 | 03:04 AM
boostedcivicsir's Avatar
Mr. Badwrench
contact john from M&H he helped me immensely with my combo
his s/n is slicksMH
Modified by boostedcivicsir at 12:55 PM 2/21/2006
Old Feb 21, 2006 | 03:38 AM
lscrx8.5's Avatar
Thanks guys for all your help!!!! Oh, and exospeed, I will definately be giving you guys a call!!!
Old Feb 21, 2006 | 08:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">Just like what everyone said, the 22x8x13 is the perfect size for what you have.
Yep just tryin to show some love.
Old Feb 21, 2006 | 09:58 AM
Default Re: (lscrx8.5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lscrx8.5 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys for all your help!!!! Oh, and exospeed, I will definately be giving you guys a call!!! </TD></TR></TABLE>
No problem.
Matador
LSVTEC 91 Civic
May 19, 2005 01:04 PM
hondahvn
Nov 11, 2003 09:04 PM
UNDER PRESSURE
Apr 21, 2003 03:25 PM
integraracer94
Oct 23, 2002 02:50 AM
92JDMSiR
Apr 18, 2002 06:52 AM
