Need Gauge Cluster HELP!!!! ASAP!!!
To make a long story short my boredum led me to taking apart most of my dash and now im having trouble putting my gauge cluster back in. Need help with some pointers to getting it back in. the car is a 94 coupe 5spd.
Short term memory problems?
Lower the adjustable steering wheel as low as it goes, then tilt the speedo cluster almost face down and bring it in from the left of the steering wheel and over the lower lip of the dash panel. Next reach over the Speedo cluster and grab the 3 green plugs and plug them into the top of the unit.
Now you can stand the unit upright inside the dash housing. 4 screws hold it in place
Lower the adjustable steering wheel as low as it goes, then tilt the speedo cluster almost face down and bring it in from the left of the steering wheel and over the lower lip of the dash panel. Next reach over the Speedo cluster and grab the 3 green plugs and plug them into the top of the unit.Now you can stand the unit upright inside the dash housing. 4 screws hold it in place
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote">Short term memory problems?
Now you can stand the unit upright inside the dash housing. 4 screws hold it in place</TD></TR></TABLE>
yes i was having short term memory problems
but i ended up figuring it out myself that exact way
Lower the adjustable steering wheel as low as it goes, then tilt the speedo cluster almost face down and bring it in from the left of the steering wheel and over the lower lip of the dash panel. Next reach over the Speedo cluster and grab the 3 green plugs and plug them into the top of the unit.Now you can stand the unit upright inside the dash housing. 4 screws hold it in place</TD></TR></TABLE>
OTI-
Jul 10, 2007 06:51 AM
redsidriver
Feb 13, 2007 11:42 AM
