shift linkage question
Old Feb 20, 2006 | 02:25 PM
J4k3's Avatar
Default shift linkage question
i have a 89 honda crx hf with a 95 b18b1 swap-93 b18a1 cable trans. today my shift linkage broke and it was a custom built linkage. they guy who owned it before me got it off another crx and in the middle it was welded together.
for now im going to re-weld it back together but i was wondering to make sure this doesnt happen again what shift linkage can i use in place of this?
i've heard a b16 linkage may work but i want to make sure its right.
thanks,
jake
Old Feb 20, 2006 | 02:35 PM
wtfda88's Avatar
sounds like u had som ***** rigged ish ahha som1 help him out
Old Feb 20, 2006 | 02:37 PM
J4k3's Avatar
Default Re: (wtfda88)
thanks for stating the obvious.
does anyone have a clue as to what would fit or am i just gonna have to make this thing as strong as possible?
Old Feb 20, 2006 | 02:39 PM
ED9 Y-49's Avatar
Default Re: shift linkage question (J4k3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J4k3 &raquo;</TD></TR><TR><TD CLASS="quote">i've heard a b16 linkage may work but i want to make sure its right.
jake</TD></TR></TABLE>
I know Hasport makes linkage for the B18 swap, but I don't know about stock replacements.
http://www.hasport.com/Products/Linkage.htm
this is what I'm talking about.
Old Feb 20, 2006 | 02:50 PM
civickiller's Avatar
Default Re: shift linkage question (ED9 Y-49)
that works if he has hasport mounts.
just have them reweld it by a welding shop, they are professionals and it wont break. and if it does break, you are shifting too hard
Old Feb 20, 2006 | 02:53 PM
J4k3's Avatar
Default Re: shift linkage question (civickiller)
i have the hasport mounts already.
im going to put a soild bar that fits just inside the pipe and then bolt that in on each side, then weld it at the seam again just for now and then later on buy the hasport.
Old Feb 20, 2006 | 02:54 PM
UltimX's Avatar
its most likly they didn't weld it good enough. Go have a professional welder weld it.
Old Feb 20, 2006 | 03:08 PM
J4k3's Avatar
Default Re: shift linkage question (UltimX)
my dad is a professional welder so we're planning something right now cuz this deffinitly was a pain in the *****.
Old Feb 20, 2006 | 03:10 PM
HondaFerris's Avatar
weld it good enough to use till you can buy the hasport linkage
Old Feb 20, 2006 | 03:57 PM
Default Re: shift linkage question (HondaFerris)
idk about any of you guys but i had problems with my hasport shift linkage. the shifter rod on the tranny side has 2 joints so pivoting. one pivots it up and down and the other left to right. the bushings on the left to right pivot wore out which left me with alot of play in my shifter.
Old Feb 20, 2006 | 05:05 PM
J4k3's Avatar
my shifter almost goes in small circles when in gear mine are worn out so bad
Old Feb 20, 2006 | 05:46 PM
but mine did this only after 4 months of owning it
VtecNotRequired
Apr 15, 2012 11:55 AM
Its me DUB
Mar 2, 2007 08:42 AM
N1ghtM0nkey
Mar 2, 2005 04:24 PM
davidcrx89
Feb 12, 2005 08:48 PM
CRX_GUY_123
14
Apr 5, 2004 09:13 AM
