D16A6 bad valve?
Old Feb 20, 2006 | 02:19 PM
9 CRX si 1's Avatar
Default D16A6 bad valve?
D16A6
What is needed to be done to get this fixed? Do I need to remove the head? We were going to get a head/valve job, but does it look like i need to? Will it be expensive?
Thanks
Old Feb 20, 2006 | 04:17 PM
civic_dork's Avatar
Default Re: D16A6 bad valve? (9 CRX si 1)
That would depend on whether or not the #3 spark plug is working or not....
But seriously, 2 ways of finding out.
1. Do/get a compression test, and follow the directions.
2. Pull the head and have a look see.
Well i guess 3rd, and quickest would involve removing the valve cover and look, maybe spin the motor with a ratchet to see if a valve is sticking, use a feeler guage and see if valve(s) is way out of spec on that cylinder... but then there are yet other possibilities: like bad rings, bad piston, bad block, bad head gasket, bad... well anything.
(and i'm sure there are other ways) Just a few guesses.
Good luck.
What type of fluid/build up is that? carbon and gas, carbon and oil, oil, water and oil? hard to tell from pic.
Old Feb 22, 2006 | 02:20 PM
9 CRX si 1's Avatar
Default Re: D16A6 bad valve? (civic_dork)
It is oil. And the compression was fine from the test.
Old Feb 22, 2006 | 02:25 PM
bluk20's Avatar
If thats so then it could be a bad valve guide and or seal...
Old Feb 22, 2006 | 02:26 PM
migizzel's Avatar
im guessing bad valve seals just my 2 cents
Old Feb 24, 2006 | 02:33 PM
civic_dork's Avatar
Default Re: D16A6 bad valve? (migizzel)
I would agree assuming the compression test was done correctly.
If compression immediately jumped to normal after 1 or 2 revolutions of the motor, i'd say yah do the seals (can be done without pulling head, piece of rope).
If compression didn't jump to normal until the 5th - 8th revolution, i'd be looking at the rings too. (i've seen a lot of people put the compression tester in the hole, sit in the car, spin the motor over a few seconds, then get out and check the gauge... won't work. Gotta watch it as it spins)
Old Feb 24, 2006 | 05:16 PM
3s0n3's Avatar
more than likely a crummy valve seal , pull the head. i have 2 d16a6 heads by the way they are both good if your interested....
Old Feb 24, 2006 | 05:26 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (ESONE S1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_dork &raquo;</TD></TR><TR><TD CLASS="quote">That would depend on whether or not the #3 spark plug is working or not....</TD></TR></TABLE>
that cyl 2 not 3
and if i remimber corectly, thats where the pvc goes into. so could just be from that.
Old Feb 24, 2006 | 06:51 PM
stankin95CX's Avatar
Does your car smoke at all? I suspect I have the same problem on my d16. It wont smoke when its idling, or when you are driving it, but when you press the gas from idle it will emit a small plume of blue smoke only if its been at idle for more than 10 seconds. Im getting ready to install a header next week so I will know for sure then, just wondering though.
Old Feb 24, 2006 | 06:55 PM
UltimX's Avatar
Default Re: D16A6 bad valve? (stankin95CX)
if the compression is good, then valve seals, steam, and rings are out of the question. the pressure would drop if it was the case. look into the pcv. I got an a6 head too!
D16SohcVtec
May 11, 2009 11:43 AM
Pandahatch
Jan 8, 2007 06:15 PM
rmcdaniels
Nov 14, 2004 04:27 PM
navin
Nov 21, 2003 11:07 AM
FAST94GSR
Dec 9, 2001 01:17 AM
