120k tune up
Hey all,
Just wanted to know if its worth it to get my 98 GSR tuned up for bout $350 at the local Honda shop? Does anyone know exactly what it consists of and if I can do it myself?
Thanks
Nate
Thanks
Nate
do the 90k service if it hasn't been done yet.
major - timing belt, waterpump, valve adjustment
along with a 15k tuneup - sparkplugs, oil change, coolant flush, tranny fluid, brakes bleed ect.....all the systems.
The 90k or 120k will never include the timing belt&water pump in it. These are always seperate repair/maintenance schedule work. $350? Is this a factory Honda or these small repair shops?
This will be what I would look for on a 120k:
Tune up: dis. cap&rotor, air filter, fuel filter, valve adjustment, spark plugs.
Replace all fluids
Check and adjust the other little things.
Replace all fluids
Damn! Too much maintenance, not enough money for being fast!!!
Replace all fluids
Replace all fluids
And no it dosent contain the timing belt and water pump. I figure maybe I should do the tune up myself and save for a clutch or something, any ideas?
[Modified by OnlyNod, 1:12 AM 3/29/2002]
Oh yeah, forgot to mention. Since your car is a GSR, I highly doubt they will replace the spark plugs because those cost like $15-$17 EACH.
I am pretty sure that the Acura Emissions Extended warranty covers the 98's too. My 97 GSR is due for the 90K and I am going to use the Emissions Warranty to cover the Plugs, Dist. Cap, and other smaller items. Check it out at a Acura shop. They will be able to tell you if your car is covered.
From acura right? I can just go get some platinum tips at Pep Boys for cheaper
You might also want to replace the spark plug wires at the same time since you have so many miles already. $48 oem from ahmotor.com
Try ahmotor.com, they sell all Honda and Acura OEM parts and their prices are usually much cheaper then dealership prices.
[Modified by mickey513, 2:41 AM 4/1/2002]
