guage cluster for hybrid hatch
Old Feb 20, 2006 | 01:30 PM
Rxmig7's Avatar
Default guage cluster for hybrid hatch
I have a 1992 civic hatchback with a b18a1 motor (stock), and a Gsr transmission. This car used to be automatic with the 1.5L motor. Now it is a 5spd. My car never came with a tachometer and I really need one now. Does anyone know wich cluster can be fitted in this car and if there's any wiring involved?
All help is appreciated.
Best regards,
Old Feb 20, 2006 | 02:56 PM
slomofo's Avatar
GDD Member
Any 92-95 civic cluster with tach.
Old Feb 22, 2006 | 11:08 AM
Rxmig7's Avatar
Thank you for your help. Now I have another problem. After 3500rpms (full throttle) the needle jumps and goes to redline and starts going crazy. Any ideas?
Thanks in advance
Old Feb 24, 2006 | 08:14 AM
slomofo's Avatar
GDD Member
Ground wire is bad somewhere, distributor might be loose, or the gauge cluster might not be plugged in all the way.
Old Feb 24, 2006 | 04:25 PM
Rxmig7's Avatar
Thanks, going to check all grounds...
Old Feb 24, 2006 | 04:44 PM
Rxmig7's Avatar
my speedometer never worked before the swap when I had the single cam. Now that I have an LS and a 94 LX gauge cluster it still doesn't work. Any ideas?
Thank you.
SpeedDemonRex
Apr 13, 2013 06:25 PM
twedter02
Sep 24, 2010 10:00 PM
hondateg10
Jan 3, 2008 07:47 AM
fast90hatch
Dec 19, 2004 07:23 AM
kikiboi
Apr 20, 2002 06:08 AM
