Euro-R Intake Manifold
Old Feb 20, 2006 | 11:58 AM
snowblind7x's Avatar
Default Euro-R Intake Manifold
How big is the opening on a Euro-R IM? I'm looking to get a tb and need to know what size to get. Should I maybe bore out the IM a lil bit and get a tb to match that? Also, what tb do you guys suggest...?
*edit* here's the only option i've found here on ht https://honda-tech.com/zerothread?id=1140381
Modified by snowblind7x at 10:17 PM 2/22/2006
Old Feb 20, 2006 | 03:15 PM
NirVTEC's Avatar
Default Re: Euro-R Intake Manifold (snowblind7x)
I have been looking at 66 & 68mm throttle bodys. I have a 70mm STR right now that I think is stealing a little low-mid range power. STR was bought out by BDL.
There are a couple of other options such as an ITR or S2K throttle body.
As far as port matching it, it can be done with a die-grinder. You most definitely do not want that lip there, it will disrupt airflow.
Old Feb 21, 2006 | 10:08 AM
bump
Old Feb 21, 2006 | 10:54 AM
Honda318dx's Avatar
stock 62mm ITR throttlebody..
Old Feb 21, 2006 | 11:58 AM
Default Re: Euro-R Intake Manifold (Honda318dx)
whats the stock bore on the Euro-R IM?
Old Feb 22, 2006 | 09:18 PM
bump
Old Feb 23, 2006 | 04:26 AM
Honda318dx's Avatar
If I remember right, its 60mm.. Most of the throttlebodys taper down 2mm.. So, the stock ITR 62mm at the filter side, and tapers down to 60mm where it meets the manifold. I remember the 60mm being flush with the port in the IM..
Old Feb 23, 2006 | 06:15 AM
redtop22's Avatar
i thought the euroR was 66mm. not sure if it tapers down on the manifold side though
Old Feb 23, 2006 | 06:37 AM
mgags7's Avatar
Default Re: Euro-R Intake Manifold (redtop22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redtop22 &raquo;</TD></TR><TR><TD CLASS="quote">i thought the euroR was 66mm. not sure if it tapers down on the manifold side though </TD></TR></TABLE>
i agree....why doesnt anyone run the euroR tb?
Old Feb 23, 2006 | 07:37 AM
2lude4u's Avatar
Default Re: Euro-R Intake Manifold (mgags7)
The Euro R T-body can be bored out to 66mm (rather than just 64mm like our stock t-bodies). The Euro/Type S/H23a vtec T-bodies are 62mm at the plate.
Old Feb 23, 2006 | 10:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
i agree....why doesnt anyone run the euroR tb?</TD></TR></TABLE>
I would run it if i had gotten it with my swap. But since i got a tiny piece of **** tb with it im just gonna buy an aftermarket one and probably port math my IM to it. I just don't know how big to go with the IM/TB or what TB to get...
Old Feb 23, 2006 | 03:39 PM
The only tb i can find here on ht is 72 mm at the intake opening and 70 mm on the IM side. Is that to big?
Old Feb 23, 2006 | 05:29 PM
The tb im thinking about getting is a RPM service tb and I can either get a 72mm tapered to 70 or a 70 tapered to 68. Which do you guys think i should get? Does anyone have any experience with RPM Service tbs? I really have no clue about anything to do with tb's. Any and all help is appreciated
*edit* I guess i can get a skunk2 tb for the same price. So any input on the Skunk2 or RPM Service tb is appreciated
Modified by snowblind7x at 6:49 PM 2/23/2006
Old Feb 24, 2006 | 12:46 PM
bump
Old Feb 24, 2006 | 02:42 PM
well i ended up getting the 68mm Skunk2 Pro Series Billet Throttle Body. Can i just get a standard H22 tb gasket for it...? Or maybe it comes with one eh...?
Daniel-sanB1
Jun 6, 2007 10:10 PM
RedRex8
May 28, 2003 09:52 PM
b16a1civichb
Feb 27, 2003 12:34 PM
JMX
Oct 14, 2001 09:49 PM
