91 Honda Starter
Old Feb 20, 2006 | 11:41 AM
BigDawwg6969's Avatar
Default 91 Honda Starter
have a quick question.... there is a wire that runs from the starter motor case.... which stud does it go on to???? need answer ASAP please!!! thanks!!!!
Old Feb 20, 2006 | 12:03 PM
90civichbsi's Avatar
Default Re: 91 Honda Starter (BigDawwg6969)
there should only be 2 wires that go to the starter, one is the signal wire that comes from wiring harness, the other is the power wire that goes from the fusebox to a stud on the case. is that the wire you were looking at?
Old Feb 20, 2006 | 12:14 PM
juice91si's Avatar
Default Re: 91 Honda Starter (90civichbsi)
one wire should be directly attached to the positive battery terminal, the other should be a small ground wire coming from the wire harness.
K33P__WR3NCHING
Apr 21, 2015 07:39 PM
sumoneEK
Aug 13, 2010 09:44 AM
Maverik4k
Audio / Security / Video
Sep 21, 2004 03:02 PM
