Antenna install - Searched and I can't find it anywhere.
Old Feb 20, 2006 | 07:28 AM
k-series's Avatar
Default Antenna install - Searched and I can't find it anywhere.
I went ahead and ordered a new power antenna since mine is broken. Are there any good how to's for this?
Edit - This is for a 92 RS 2 door DA.
Thanks,
Steve
Old Feb 20, 2006 | 09:10 AM
DA jeshy's Avatar
Default Re: Antenna install - Searched and I can't find it anywhere. (k-series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k-series &raquo;</TD></TR><TR><TD CLASS="quote">I went ahead and ordered a new power antenna since mine is broken. Are there any good how to's for this?
Thanks,
Steve</TD></TR></TABLE>
im going to be doing the same thing, so when u do the install let me know how it went.
Old Feb 21, 2006 | 04:31 AM
k-series's Avatar
Default Re: Antenna install - Searched and I can't find it anywhere. (DA jeshy)
This is for a DC2...I'm hoping that it's similar.
http://www.team-integra.net/se...D=914
Steve
Old Feb 21, 2006 | 07:44 AM
rkrone's Avatar
go to hondahookup.com and download the manual in pdf form, it tells you how to do it
Old Feb 22, 2006 | 08:23 AM
Cliffjumper2's Avatar
It's fairly self explanatory.
Loosen the top locking ring on the outside of the car.
You'll have to remove the rear plastic panel, and then take off a couple fastners from the side panel, enough to bend it away for the side of the car without cracking it.
At that point there will be two small nuts, one toward the top of the antenna unit, and one towrd the bottom. Loosen those.
Then there is a drain hose and a power connector; disconnect those.
Go back to the outside locking ring, and finish unscrewing it; the antenna unit should drop out at this point.
Replace it with the new unit, in reverse of the way you took it out, making sure to reconnect the drain hose properly.
You'll see it's fairly simple, but make sure to do it during the day as it's cramp space and kinda dark.
Built B16A
Audio / Security / Video
Jan 28, 2010 08:16 AM
tweek_boii
Jan 21, 2008 08:56 PM
95greenteg
Sep 13, 2005 06:48 AM
sotn10
Feb 2, 2005 09:21 PM
tdawson33
Nov 23, 2004 05:26 PM
