Which Gear Ratios For B16 Hydro Tranny??
Old Feb 20, 2006 | 07:17 AM
Scharn's Avatar
Default Which Gear Ratios For B16 Hydro Tranny??
I need some input on which short ratio gears to get. Application for 1/4 mile drag. I mean maintaining the stock tranny housing and changing stock 1st, 2nd, 3rd, 4th and 5th ratios for shorter ones. Currently I've heard for KAAZ and ATS. Which one would be a better choice for 1/4 drag? Or are there other ratios out there? Straight cut dog box is way out of my budget. Your inputs will be very much appreciated.
Old Feb 21, 2006 | 10:55 AM
ExospeedAMcrx's Avatar
Default Re: Which Gear Ratios For B16 Hydro Tranny?? (Scharn)
need more info on what you are planning to do?
I'm assuming All Motor. Whats the power output, slick size you plan to use, street car or full race car?
Old Feb 22, 2006 | 03:18 AM
Scharn's Avatar
Default Re: Which Gear Ratios For B16 Hydro Tranny?? (exospeedAMcrx)
I'm running all motor. B16B CTR head on B20B block with JE 84mm high comp pistons. Chasis: JDM 90 crx, fully stripped. Tranny comes from a JDM EG6 with 4.4 final drive. Purchased a cusco LSD. Slick size: 205/50/15. Strictly race. Motor output should be in the region of 220+ whp.
mrx
18
Feb 25, 2013 05:21 AM
DOMKID
Sep 27, 2005 07:27 AM
jdmlsvtec
Sep 24, 2003 11:36 AM
eddiecut
12
Jun 26, 2003 10:46 AM
lazyguy
May 31, 2002 05:33 AM
