Suspension & Brakes Theory, alignment, spring rates....
Type R rear control arms on a EK... help
Old Feb 19, 2006 | 11:16 PM
c5_el's Avatar
Default Type R rear control arms on a EK... help
will type r rear control arms work on a ek civic? are the lengths the same? will it have any affect on camber? i want to use type r coilover setup on my ek and need to know if this will work, thanks
Old Feb 20, 2006 | 01:48 AM
slammed_93_hatch's Avatar
Default Re: Type R rear control arms on a EK... help (c5_el)
you can't use ITR rear LCA on a EK civic.
Old Feb 20, 2006 | 08:44 AM
c5_el's Avatar
can u please explain why? thanks
Old Feb 20, 2006 | 09:57 AM
hayabusa160's Avatar
Default Re: (c5_el)
the ek has longer lca then the eg and dc2. there is no way you can put the type r lca on the ek. if you do it will pull the suspension inward giving you an insaine mount of positive camber you wont be able to drive the car in a safe manner.
xbabysharkx
Dec 15, 2010 12:41 PM
WhiteEKgsr
Suspension & Brakes
Mar 23, 2008 06:53 AM
paulzy
Apr 12, 2003 01:23 AM
delux247
Mar 29, 2003 08:40 AM
Ehron
10
Jan 17, 2003 05:19 AM
