BC spec 2 set up
Old Feb 19, 2006 | 10:19 PM
dohcteg's Avatar
Default BC spec 2 set up
Hi everybody. Im new to HT so i hope to learn from u guys. Anyways i just got my 2001 2dr teg LS. Its all stock at this point (bsides the intakes). My 1st mod i want to do is exhaust system. I want to go with the BC spec 2. I heard this system is pretty loud but it sounds good, wut do u guys think? Well i did some research and found out that the BC spec 2 system has a 2.38inch piping only NOT 2.5inch. So does that mean i have to get a headers with 2.38inch collector and 2.38inch hi-flow cat too? Or will the 2.5" headers collector will be fine?
BTW what is the collect size for dc headers? How come i kept hearing people saying the dc JDM 4-1 headers has a 2.5inch collector.... theres a JDM for DC??? i thought all DC are the samething? Wuts the other size collector then? Can u guys clear up. THANK YOU all very much. Im hoping to get this clearified and get started on my car. Ill post up pix when its ready.
Old Feb 19, 2006 | 10:23 PM
teggy182's Avatar
Default Re: BC spec 2 set up (dohcteg)
jdm size is 2.5 others are 2.25
Old Feb 19, 2006 | 10:44 PM
dohcteg's Avatar
OOs thnx for the reply. So should i go with a 2.5" header + cat and bc exhaust? Or should i stick with the 2.25" headers collector? BTW i can't find any hi-flow cat with a 2.38" openning that connects to the exhaust. THANKs
whiteteggy44
Jan 11, 2011 05:07 PM
RA217252
Jul 27, 2005 11:12 PM
MugenKid18
May 26, 2004 08:03 PM
IC x Prince
Mar 7, 2003 06:36 AM
Halo
Feb 3, 2002 09:25 PM
