90-93 ls cluster into an ef 88-91 civic
Old Feb 19, 2006 | 07:53 PM
CR-V-tech's Avatar
Default 90-93 ls cluster into an ef 88-91 civic
I have already wired mine up but it just lays on the dash cuz I can't get it to fit so I need to know how or what to trim to get it to fit? any info would greatly appreciated thanks
Old Feb 20, 2006 | 12:33 AM
badboyr66's Avatar
Default Re: 90-93 ls cluster into an ef 88-91 civic (CR-V-tech)
You really just have to try and fit it then cut where it does not clear. I have a 98 cluster in mine.... and after a few hours it looks like itt is supposed to be there... under the stock gauge cover and all
Old Feb 20, 2006 | 05:36 AM
123_vtec's Avatar
Got pics and infos in the link: https://honda-tech.com/zerothread?id=1513450
But dont do like me rushing through it. You are rather cut less then more than needed. And don't cut both the black and glass bezel yet. Good luck and let me know how it goes. Oh at the end, all you need to do is remove the old stock brackets, and stuff the cluster in there. If you hate rattle, you can stuff some foam or shipping materials in there to keep it from vibrate against other parts. Have fun.
Old Feb 20, 2006 | 05:45 AM
ijjz's Avatar
Default Re: 90-93 ls cluster into an ef 88-91 civic (123_vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 123_vtec &raquo;</TD></TR><TR><TD CLASS="quote">Got pics and infos in the link: https://honda-tech.com/zerothread?id=1513450 </TD></TR></TABLE>
Looks like its a little to long in those pics, fuel and temp are partly cut off. Even if you went slow, I dont see how it would fit better.
Old Feb 21, 2006 | 08:41 AM
CR-V-tech's Avatar
Default Re: 90-93 ls cluster into an ef 88-91 civic (ijjz)
bump and thanks for all the info
STPREZ
Mar 30, 2012 07:36 AM
boostedEGD16Z6
Jan 20, 2011 04:33 PM
Whitfield Inc.
Jan 17, 2004 10:18 PM
7PSiEF9ZC
Oct 24, 2003 07:08 AM
YumVTEC
Feb 22, 2003 12:51 PM
