O.E.M. sway bars
according to grabka.org, it has a 21mm front, the si had a 22, neither had a rear.
looks like the same size as the gsr one its tiny. 14mm i guess.
i took one off a parts car,
that car also have dc2 front brakes. and the nm260v brake booster same one off the integra rs and 96 spec type r. but one of the fitting is not the same size so its not a straight bolt on a civic.
What spring rates do run? with stock springs just the 14mm rear would have to be pretty roll-intensive. Dont get me wrong, going from nothing to a 14mm is a great upgrade, but still leaves some to be desired. I got my gsr from a friendly donor junkyard teg, and I was very happy for a while, then got bit by the upgrade bug- 24mm front, 19 rear and the ASR brace. That should last me a while...
this is what i have found out so far 92-95 4dr ex w\abs 13mm rear, integra14mm rear,del sol vtec 15mm rear,92-95 si 21mm front,integra 22mm front, havent found out what the 4dr uses in the front but i would think it was a 22mm bar
