Accord Bulb problem
Old Feb 19, 2006 | 01:49 PM
Ruskimafia's Avatar
Default Accord Bulb problem
I have a 00 accord i had this car for about year now.So i replaced the head light bulbs to some Silver Stars. i Had them for about a month and the drivers side blew so i replaced it w/ stock and kept psss side in a week past and the other side blew. So then i got some other clear blue bulbs put them in they blew a month later to.
IM not a noob at installing bulbs. AND DID not tocuh the bulbs w/ fingers
What can be causing this to happen ?
And now im with stock pee yellow color bulbs that dont seem to blow at all
Old Feb 19, 2006 | 02:12 PM
P_Adams's Avatar
Default Re: Accord Bulb problem (Ruskimafia)
There have been some discussion in here with regards to Silverstars' having a short(er) than normal (due to burning hotter) life.
This I can't confirm because, well, all three cars listed in my sig run Silverstars, and the two 5th Gens continue to burn original Silverstars after three years.
Vibration can effect bulb life, as can water intrusion (something that isn't normally an issue with Honda's. You've already covered the issue of handling Halogen Bulbs; so that leaves just one question...
This isn't a 6th Gen V6 with a Denso Alternator is it?
They've had some over charging issues which involved blown bulbs, a toasted ECM and other exotic WTF? failures.
Other than that, it could be just poor dumb luck.
P
Old Feb 19, 2006 | 02:29 PM
Ruskimafia's Avatar
Yea this is 6th Gen V6 with a Denso Alternator But has been replaced to Bosch Alternator
Old Feb 20, 2006 | 08:59 AM
Ruskimafia's Avatar
can the alternator be causing these bulbs to blow ?
Old Feb 20, 2006 | 09:06 AM
mafia's Avatar
Default Re: (Ruskimafia)
I dout it, but you should try something els mabe? ti ruski?
Old Feb 20, 2006 | 09:12 AM
philadd's Avatar
Default Re: (mafia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruskimafia &raquo;</TD></TR><TR><TD CLASS="quote">can the alternator be causing these bulbs to blow ? </TD></TR></TABLE>
Ah hemm....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">There have been some discussion in here with regards to Silverstars' having a short(er) than normal (due to burning hotter) life.
P</TD></TR></TABLE>
Just pointing out that he already answered that question. Am I the only one that reads?
Old Feb 21, 2006 | 10:47 AM
Ruskimafia's Avatar
lol yea u are the only one that reads
Yes Mafia i am Russian
Old Feb 21, 2006 | 10:57 AM
XzIpK's Avatar
holla @ the mini russian crew on honda-tech lol
(Im russian too)
Old Feb 21, 2006 | 02:21 PM
Hcivic88's Avatar
Default Re: (XzIpK)
i think one reason u may be blowing them is because you're changing one at a time.. usually when u change only one bulb, the other one will blow... you're usually supposed to replace bulbs in pairs. although why the silverstars blew in the first place is beyond me
Old Feb 21, 2006 | 02:46 PM
glamXXXrock's Avatar
Silverstars suck... I've gone through probably 3 sets of them in two years... why I kept buying them, I don't know... I'm a moron
Old Feb 21, 2006 | 03:32 PM
philadd's Avatar
Default Re: (Hcivic88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic88 &raquo;</TD></TR><TR><TD CLASS="quote">i think one reason u may be blowing them is because you're changing one at a time.. usually when u change only one bulb, the other one will blow... you're usually supposed to replace bulbs in pairs. although why the silverstars blew in the first place is beyond me </TD></TR></TABLE>
I don't see how only changing one bulb can possibly cause the other to burn out. Not to mention, I have never had that problem... Manufacturers recommend changing both of the bulbs at the same time to supposedly insure that both bulb have the same brightness. Personally, I believe they just want you to buy another bulb so that they make more money.
If it was necessary to replace both bulbs at the same time, then why do some manufacturers sell headlight bulbs in single packs?
poland accord
Sep 10, 2007 05:13 PM
angelovargas
Oct 15, 2004 01:23 AM
raza203
Oct 4, 2004 08:33 PM
puckster02
Mar 11, 2002 07:19 AM
