Battery help ! ! !
Old Feb 19, 2006 | 01:42 PM
Vtakkk's Avatar
Default Battery help ! ! !
Ok for the past week or so my battery has kept dying, id have to jump my car to get to work, ill drive for about 15 min, and when it comes time to go home my batt is dead! ! ! So I have a co-worker jump it, and today I was putting my ksports in and had to jump it 3 times, so I take it for a test drive to see how my susp is, and after about 15 min of driving, I go home and turn my car off, 2 min later I go to start it, the battery is dead, the dash lights started out bright, and after I tried turning it over, the lights got dim as hell
WTF !?!?!?
Old Feb 19, 2006 | 01:45 PM
SiR Inspired ED7's Avatar
Default Re: Battery help ! ! ! (Stupid EF)
Replace Your Alternator
Old Feb 19, 2006 | 01:48 PM
Vtakkk's Avatar
Default Re: Battery help ! ! ! (88 Crx Si)
Should I be automatically ruling it out as the alternator ? ?
Old Feb 19, 2006 | 01:53 PM
3s0n3's Avatar
sounds like you need a new batt. its not holding charge..... does it have a warentty?
Old Feb 19, 2006 | 01:54 PM
mahatma's Avatar
Default Re: (ESONE S1)
Take the battery out and have it tested. If it tests ok, you know the problem is the alt
HardSaltydogg's Avatar
does it turn off on you while the engine is running?
Old Feb 19, 2006 | 01:56 PM
Vtakkk's Avatar
Default Re: Battery help ! ! ! (HardSaltydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HardSaltydogg &raquo;</TD></TR><TR><TD CLASS="quote">does it turn off on you while the engine is running?</TD></TR></TABLE>
No, Ill connect the wires for a jump, and it goes really fast, but literally the second my car is off, the battery dies. It will drive and everything will be fine up until the moment I turn my car off.
snowseeker's Avatar
Start the motor, pull the negative wire off the battery, car dies = replace alt. car runs = replace battery.
Old Feb 19, 2006 | 02:00 PM
Vtakkk's Avatar
Default Re: Battery help ! ! ! (snowseeker)
sounds simple enough, thank you
stupendousman
Honda Civic (2001 - 2005)
17
Jan 2, 2013 08:40 PM
freak^
Sep 6, 2010 08:42 PM
disposable
Jun 26, 2008 08:02 PM
mouch33
May 1, 2008 05:38 AM
HybridHatchC1
22
Dec 11, 2004 10:35 PM
