does anyone make an adapter mount for accord trans in a prelude
Old Feb 19, 2006 | 01:28 PM
ismkv8s's Avatar
Default does anyone make an adapter mount for accord trans in a prelude
As the title says.
Old Feb 19, 2006 | 02:14 PM
SteveoBA8's Avatar
Default Re: does anyone make an adapter mount for accord trans in a prelude (ismkv8s)
All F and H series will bolt up.
Old Feb 21, 2006 | 07:09 PM
ismkv8s's Avatar
Default Re: does anyone make an adapter mount for accord trans in a prelude (SteveoBA8)
Thats not true because I have all bolted in a 92accord ex trans and the mount if it fit is to low and forward about an ince and a half. If you give me your email I can send you pics. And the prelude trans mount does not bolt up at all.
Old Feb 21, 2006 | 07:18 PM
sloaccord's Avatar
New User
if you look at your tranny it will have holes where you need the motor mount bolts to be.
remove old bolts.
drill and tap tranny.
install old bolts in new location.
ta da, if fits.
all f & h trannies fit all cb/bb/cd/whatever chassis. no adapter needed.
Old Feb 21, 2006 | 07:27 PM
93H22APrelude's Avatar
Default Re: does anyone make an adapter mount for accord trans in a prelude (sloaccord)
all f/h series tranny will fit... there are plenty of people that done this with no problem direct bolt on... search it
Old Feb 22, 2006 | 05:42 AM
Honda318dx's Avatar
Default Re: does anyone make an adapter mount for accord trans in a prelude (93H22APrelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93H22APrelude &raquo;</TD></TR><TR><TD CLASS="quote">all f/h series tranny will fit... there are plenty of people that done this with no problem direct bolt on... search it </TD></TR></TABLE>
Not if your using a 1990-1993 Accord transmission. The holes for the mount are different. you must drill and tap new holes in the housing (there are spots for them) for the studs to sink into.
Old Feb 22, 2006 | 08:25 AM
Default Re: does anyone make an adapter mount for accord trans in a prelude (Honda318dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda318dx &raquo;</TD></TR><TR><TD CLASS="quote">
Not if your using a 1990-1993 Accord transmission. The holes for the mount are different. you must drill and tap new holes in the housing (there are spots for them) for the studs to sink into. </TD></TR></TABLE>
ok my mistake "CORRECTION"
dartonh22
Jan 31, 2008 05:08 PM
pinecone
Oct 1, 2007 07:56 PM
Gabbiani
Jun 14, 2005 08:23 AM
underpressure02
Mar 26, 2005 04:10 PM
DMF
Oct 12, 2003 09:30 PM
