FS: OBDI Full Race Engine Harness (Brand New)
Old Feb 19, 2006 | 12:05 PM
Kataku2K3's Avatar
Default FS: OBD1 Full Race Engine Wiring Harness (Brand New)
SOLD on eBay!!!
Just as the topic says, it's a brand new and complete, OBDI full race engine harness. That is just to say, this harness alone, with a 12V+ power source, ground, starter signal (12V+), and OBDI ECU will run any B or D series Honda engine.
I normally make these harnesses custom, discussing with the buyer first, exactly what they want (sensor wise), and what type of setup it will eventually be running, but I had some extra harnesses laying around and just put this one togther. As most of my work is, it's intended for a B series VTEC motor, but will also work on a nonVTEC setup (as well as with D series - the sensor wires are plently long either way). Being that it's a little more "standalonish", you do however need a way to bypass the electrical load detector in the ECU (since you are no longer running a factory under the hood fuse box), but this is easily done with most aftermarket engine management systems such as Hondata, etc. I also did not wire a knock sensor, as most people people either don't need it, or disable it (again done with the EMS should you have a DOHC VTEC ECU) If you however desire one, it could be added in very easily. Beyond that it has all the standard connections just as any OEM harness (distributor, alternator, and injectors are all setup for OBDI, but again, could be changed out should you need to do so). Though I'm trying to keep this decently short, I should mention that at the ECU end, there are inputs for the brake switch (BKSW - some of the higher end Hondata systems can use this) and for the service connector (SCS - grounded to activate the check engine light), and outputs for the CEL and tach, all which are labeled.
<U>All soldered connections, using Micro 375-100 loom, wrapped in 3M Super 33+. </U>
The price may seem a little steep, but you have to take into consideration that I normally charge ~$400 for labor alone when the customer is paying for shipping and sending me a harness to be reworked (here I am supplying both). If you have any questions (I would assume we would have some here) or would like more high res. pics feel free to PM/Email me. Thanks, -Adam Uyemura
EDIT: Forgot to add, but if you would like any references, I've got quite a few people on H-T who can vouch for me.
Complete harness (ECU not included) - SOLD
Connectors close-up
ECU connections close-up
Modified by Kataku2K3 at 11:07 AM 3/19/2006
Old Feb 19, 2006 | 05:32 PM
Kataku2K3's Avatar
Default Re: FS: OBDI Full Race Engine Harness (Kataku2K3)
To The Top since the classifieds move like CRAZY!
Old Feb 20, 2006 | 09:01 AM
Kataku2K3's Avatar
UP after class!
Old Feb 20, 2006 | 09:16 AM
impact_blu's Avatar
bump, harness looks clean....you don't happen to do any custom k harnesses onto obd1??
Old Feb 20, 2006 | 10:05 AM
Kataku2K3's Avatar
Default Re: FS: OBDI Full Race Engine Harness (impact_blu)
Thanks for the BUMP and compliment! What do you mean by K series to OBDI? Not like using an OBDI ECU to manage a K motor, right? If you're talking about a "full race" (like this one - where you just need power to run it), K series harness, I haven't done any of those, but I guess I could since I'm starting another K harness right now. This isn't one of my race ones, but it's a direct plug-n-play setup I did awhile back for a K motor into an '96-98 Civic.
NOT FOR SALE - I'll probably have one done shortly though
Old Feb 20, 2006 | 06:51 PM
Kataku2K3's Avatar
You guys are probably getting sick of me bumping this... Maybe I should have some other help!
Old Feb 20, 2006 | 08:27 PM
5thgenallmotor's Avatar
BUmp for U since I read it on page 5
Old Feb 20, 2006 | 10:56 PM
Kataku2K3's Avatar
Default Re: FS: OBDI Full Race Engine Harness (5thgenallmotor)
haha thanks! Topsides before bed again...
Old Feb 21, 2006 | 12:35 AM
EnjoyTheRideDC2's Avatar
BUMP for some clean looking harnesses. WOW
Old Feb 21, 2006 | 11:43 AM
Kataku2K3's Avatar
Default Re: FS: OBDI Full Race Engine Harness (EnjoyTheRideDC2)
Thanks again!
Old Feb 23, 2006 | 05:43 PM
Kataku2K3's Avatar
TTT, after midterms...
Old Feb 23, 2006 | 11:17 PM
jdmDXrex's Avatar
Up for Adam...
Old Feb 25, 2006 | 11:17 AM
Kataku2K3's Avatar
BUMP
Old Feb 25, 2006 | 01:07 PM
93civicEX's Avatar
bump
Old Feb 25, 2006 | 02:07 PM
LSEGHATCH's Avatar
Default Re: FS: OBD1 Full Race Engine Wiring Harness (Kataku2K3)
Subscribed for a later date
Old Feb 26, 2006 | 08:14 AM
Kataku2K3's Avatar
Thanks guys!
Old Feb 26, 2006 | 11:17 PM
Kataku2K3's Avatar
It's late, and no one's probably up, but whatever...
Old Feb 27, 2006 | 01:03 PM
JDMSiGuy17's Avatar
bump for one clean harness!!! thinking hard about getting one from ya!!!
Old Feb 28, 2006 | 08:53 AM
Kataku2K3's Avatar
Default Re: FS: OBD1 Full Race Engine Wiring Harness (JDMSiGuy17)
Thanks, and if anyone is ever interested in a custom one, just let me know! Morning BUMP before a loooooong day of class/studying...
Old Mar 1, 2006 | 10:23 PM
Kataku2K3's Avatar
Topsides
Old Mar 3, 2006 | 09:10 AM
Kataku2K3's Avatar
BUMP before I wash the Pilot in this freezing *** cold weather!
Old Mar 6, 2006 | 10:21 AM
Kataku2K3's Avatar
TTT
Old Mar 6, 2006 | 10:52 AM
JCracer723's Avatar
bump !!
Old Mar 7, 2006 | 09:08 AM
Kataku2K3's Avatar
Default Re: FS: OBD1 Full Race Engine Wiring Harness (JCracer723)
Thanks
Old Mar 8, 2006 | 06:07 AM
Kataku2K3's Avatar
BUMP
