Custom racing B-series vtec distributor/ignition and more..Cams,cats,snapon tools
Snapon compression tester new in the box. Part # mt308kb
This wa used 1 time..The only drawback is that the gauge is only good to 250 psi.. My allmotor stuff goes up to 300 so this wont work for me anymore.
Finally my og wheels.
These are real deal Racing Hart cp035's that have been powdercoated black.They still have the original bronze under so you could strip off the powder coat if you want them gold. These are the lightest 15 in forged wheel on the market to my knowledge..They are only 6.5-7lbs if i remember correctly..
I'll throw in the tires for free. Up front are bfg drag radials 205x50x15 , the tread patteren is worn down pretty good on these BUT they still grab as good if not better then new. In the rear are potenza RE010's with 88% tread left and they are still like new. 1 wheel has a few chips in the black powdercoat so you can see the gold in those spots..These are used and not ijn any way showcar shape..
They are forged racing wheels and thats what they were used for..lol
I'll let these go for the first 850.00.. these rims alone are over 400.00 a piece new..The rims were not cleaned at all for the pics, so they are very dirty..lol
They are 7lbs each if I remember correctly.
Ok and 1 last non honda item..
I have a brand new in the box Magnaflow dual exhaust for a 2000-2003 extended cab Dodge Dakota.. Magnaflow Model 15736.
This sells for 642.72 new...
Mine is still new except some minor scratches in some of the pipes from test fitting iit on my truck .. didnt workout since I have a quad cab with a lift..
I'll let this go insanly cheap....375.00
Email is tbone327@***.net
paypal verified
postal money orders accepted..
I'm always up for trades on some of it..
Update.
I have abrand new in box set of Eagle .137log LS vtec rod's
These are used so that you can have the extra displacement of the ls crank all while still using the factory rod stroke ratio of an Integra type r.
300.00 or best offer
Last one here for tonite is a set of supertech .5mm intake overesize high cr flatface valves with a set Rocket motorsports flat face 2 piece racing flat valves.
Accepting reasonable offers on all 16 high cr valves,
Modified by Tbone at 3:29 PM 2/19/2006
Modified by Tbone at 11:13 PM 2/19/2006
Modified by Tbone at 5:12 PM 2/20/2006
Modified by Tbone at 10:30 PM 2/20/2006
Modified by Tbone at 6:33 PM 3/13/2006
EF'n Sedan
Southeast (Sales)
Aug 1, 2010 01:01 PM
Tbone
Jul 20, 2006 08:00 AM
ExospeedAMcrx
22
Jun 4, 2004 11:39 PM
chrisir19
Jan 11, 2004 06:09 AM
