SOHC ZC not running right please help!
Old Feb 19, 2006 | 10:22 AM
migizzel's Avatar
Default SOHC ZC not running right please help!
ok i recently installed an OBX IM with a B16 TB AEM fuel rail and B&M regulator also intalled brand new plugs ,wires cap and rotor and i still have a miss on it you can hear the exhaust putt-putt but not all the time and at high rpms seems like i have not a hole lot of power what could cause this ???
also im running a stock pm6 on it could that be my problem?
Old Feb 19, 2006 | 10:28 AM
xaine's Avatar
Default Re: SOHC ZC not running right please help! (migizzel)
you will have to re check evrything
like the wires and plugs
was the gap set correctly?
was the fuel pressure set correctly?
i have have wires be bad ,even brand new, before
make sure there is no leaks in the manifold
if its missing , probably in the ignition of fuel
just eliminate each thing until something doesnt work right
Old Feb 19, 2006 | 10:31 AM
migizzel's Avatar
Default Re: SOHC ZC not running right please help! (xaine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xaine &raquo;</TD></TR><TR><TD CLASS="quote">you will have to re check evrything
so what is the correct fuel pressure some pepole tell me is 40 psi others 32 and some 28 psi
Modified by migizzel at 11:42 AM 2/19/2006
Old Feb 19, 2006 | 03:34 PM
migizzel's Avatar
bump anybody ?
Old Feb 19, 2006 | 03:46 PM
migizzel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migizzel &raquo;</TD></TR><TR><TD CLASS="quote">bump anybody ?
DAtegLs
Aug 2, 2010 08:57 PM
spluvs2install
34
Jan 14, 2007 08:58 PM
migizzel
Feb 22, 2006 11:56 AM
96-EJ6 B18C
Apr 15, 2004 05:33 PM
Magick211
14
Dec 21, 2001 06:18 AM
