best suspension upgrade for my teg
Old Mar 27, 2002 | 05:27 PM
vtec_addict's Avatar
Default best suspension upgrade for my teg
hello all, I am sumwhat new to all this and would like to here your opinions on suspension upgrades.
I basically want to be able to have a good ride with some improvement in cornering.
what I have in mind is an eibach pro-kit, & koni (yellows), and prolly a energy suspension master poly bushing kit. what do you all think of these mods.?
Old Mar 27, 2002 | 05:30 PM
teg92's Avatar
Default Re: best suspension upgrade for my teg (vtec_addict)
You've got good senses! Very good setup. I might advise going with Sportlines however, a lot of people always wish they went lower the first time.
Word of advice: As much as you're probably tempted to do those mods one at a time, I'd really recommend only installing the springs once you can afford shocks at the same time. Why? Saves you on labour (if you do it yourself too!!) and you'll get a lot more out of it. I wished people stressed this more. Too many people drive around on lowering springs and stock shocks that are leaking through the ying yang.
Old Mar 27, 2002 | 05:34 PM
00VTEC's Avatar
money for money...pound for pound...ITR rear sway bar w/ bsq kit.
[Modified by 00VTEC, 9:50 PM 3/27/2002]
Old Mar 27, 2002 | 05:42 PM
SYDNEYSIDER's Avatar
Default Re: best suspension upgrade for my teg (00VTEC)
money for money...pround for pound...ITR rear sway bar w/ bsq kit.
Ditto
Old Mar 27, 2002 | 05:58 PM
D.Lansing's Avatar
Default Re: best suspension upgrade for my teg (GS-R_ocks)
I wouldn't recommed the bushings. It is a very labor intensive ordeal, which unless you are more mechanically inclined than most, will cost you $. I've also heard that the polyurethane bushings tend to get sloppy over time. This is because that although they do flex less than the stock bushings, when they do flex, they have problems returning to their normal shape. I have no firsthand experience with this however, just have heard a couple of testimonials.
Old Mar 27, 2002 | 08:56 PM
bocian's Avatar
Default Re: best suspension upgrade for my teg (D.Lansing)
ITR sway bar with bsq's kit !!!
Old Mar 27, 2002 | 10:08 PM
GreenD's Avatar
Default Re: best suspension upgrade for my teg (bocian)
definetly itr sway w/ bsq or beaks.
Old Mar 28, 2002 | 03:41 AM
Neo's Avatar
Neo
Default Re: best suspension upgrade for my teg (Brandon Chun)
As already mentioned, the ITR sway bar with one of the reinforcement kits is the way to go. Last May, I did that mod along with installing Koni yellows and Comptech sports springs at the same time, and I'm still smiling... If you can afford to do it all at the same time, it's well worth the $$, time and effort. The Konis are a terrific shock, but they'll set you back around $500 for all four. Any "sport" spring will drop you ~1.5" and won't be too stiff that you'll regret it later. If you've only got the $$ for one mod, then do the sway bar; you won't regret it.
Old Mar 28, 2002 | 06:48 AM
Forgive me for being a little slow here but what is the BSQ mtg kit.
Old Mar 28, 2002 | 06:54 AM
bps2799's Avatar
Perform a search for posts created by BSQ.
He created/sells a mounting kit so that you can mount the superior ITR (type-R) sway bar on lesser 'tegs w/o have the increased strain tear out the rear sub-frame.
Old Mar 28, 2002 | 12:29 PM
would everybody agree that poly bushings may be more of a pain than there worth.
any other suggestions besides doing the shocks and springs and sway bar.. I got money to burn here (tax refund)...
Old Mar 28, 2002 | 02:39 PM
ALF's Avatar
ALF
If you want a "good ride", I'd advise against the polyurethane bushings. It does a GREAT job of stiffening up everything, but at the expense of squeeks (they require regreasing) and noticeable harshness over stock. It's up to you though.
The setup you described sounded perfect. You won't regret it. But you should use the money you intended to use for the ES bushings and go for the ITR swaybar without a doubt...or if you have money like that, get the Comptech swaybar/tiebar combo.
Old Mar 28, 2002 | 05:59 PM
RC211V's Avatar
Default Re: best suspension upgrade for my teg (GreenDestiny)
the comptech rear sway and lower tie work well as well. good investment.
Old Mar 28, 2002 | 06:06 PM
Phoenix_ITR's Avatar
Old Mar 28, 2002 | 06:25 PM
AzN_Flava's Avatar
i do not have this mod yet... but hehe soon... and I've only heard great things about it... you should definitely go for this!!!
By the way... welcome to honda-tech...
Old Mar 28, 2002 | 07:21 PM
Brandon Chun's Avatar
I got to agree Itr Rear Sway Bar with BSQ's mounting kit!
Old Mar 30, 2002 | 12:13 PM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
F*** the ITR sway bar. No offense but just because it says R on it doesn't mean its the best. You want the best, COMPTECH sway and tie bar combo. Yeah its expensive but you can adjust it and ur car will have no body roll what-so-ever. Thats just my thaught.
Old Mar 30, 2002 | 01:06 PM
robbin's Avatar
Default Re: best suspension upgrade for my teg (SupersonicBlueGSR)
"best" is a relative term for sway bars. Obviously, if the comptech unit is adjustable than that's a good feature, but you want to get the bar that will make your car handle the way you want it too. The Mugen 26mm bar might make your car rotate more than you want it too, and the stock (14.7mm I think) bar is way too small. The ITR (22mm, 23mm JDM) is probably a good compromise (and the best priced). It's not adjustable but unless you plan on getting into some form of motorsport you may not need an adjustable bar.
Old Mar 30, 2002 | 05:38 PM
IN VTEC's Avatar
If you need help installing the ITR rear swaybar with a mounting kit, e-mail me and I can help you do it.
Or, if you're still iffy on whether or not to get it, I'll take you for a ride.
Old Mar 30, 2002 | 11:38 PM
White98LS's Avatar
Default Re: best suspension upgrade for my teg (IN VTEC)
You might consider the Neuspeed Sports over the Pro-Kits or Sportlines. They have a softer front spring rate but stiffer rear relative to the Sportlines, which makes the car handle more neutrally. However, if you are going to do the ITR swaybar, you'd have plenty of rear stiffness, so in that case I would stick to the Eibachs.
Old Mar 31, 2002 | 02:20 AM
MintyDip's Avatar
Default Re: best suspension upgrade for my teg (White98LS)
I Love members like you!!!
New, bu tliek the right things
Koni
Prokit
ITR SWAY=
my exact setup. Best way to spend moeny if u care about suspension
Old Mar 31, 2002 | 08:02 AM
HondaJon's Avatar
Default Re: best suspension upgrade for my teg (MintyDip)
Ground Controls with Custom Rates (ERS Springs)
Koni Yellows
ITR rear sway bar with BSQ mounting kit
Old Mar 31, 2002 | 10:16 AM
ALF's Avatar
ALF
You're forgetting the most biggest reason as to why people get the ITR swaybar...performance to cost factor. I'd rather pay $120 for ITR swaybar, polyurethane swaybar bushings, and a BSQ kit than $330+ for a Comptech tie/swaybar. They both do the same thing. Of course, if you want a tie bar with that, and don't mind paying the cost, good for you. If I wanted to, I can buy a Benen lower tie bar for $130 (retail) and everything would still total out to less than $330. Hell, I'd probably use the rest of the money to get a few polyurethene bushings to stiffen up the suspension even more. Tell me who has the better suspension now? That's just my thought.
And no, people don't buy it just because it's "Type R." It's proven to provide neutral handling on our forward plowing, understeering like pigs, regular Integras.
That's a first...someone who won't get something because it's from an ITR.
Old Mar 31, 2002 | 10:29 AM
mattL's Avatar
Default Re: best suspension upgrade for my teg (Dozed)
sounds like i should get an Itr sway bar. Wheres a good place to pick one up at a decent price? i'm a little surprised that no one likes coil overs, i like mine lots, i'm sure that a full spring is better performance wise but mine handle and ride really nice. The main reason i like them though is cause i can set my car exactly how i like it, and as i change wheels i can adjust it for the best look. Oh what are BSQ's? sorry but i'm not familiar with them thanks
Old Apr 1, 2002 | 06:36 AM
BSQ's Avatar
BSQ
Default Re: best suspension upgrade for my teg (mattL)
A&H Motorsports ( http://www.ahmotor.com ) has good prices on the Type-R rear swaybar and the misc. parts. But I recently found out that http://www.acuraautomotiveparts.net has better prices than A&H. Just for comparision, the total price (swaybar, misc. parts, S&H) from http://www.acuraautomotiveparts.net is $85 and $105-$110 from A&H.
What's a BSQ?...What's a BSQ? Just kidding around with ya!!!
I'm BSQ and I make and sell a mounting/reinforcement kit (often referred to as BSQ kit or BSQ mounting kit) for the installation of the Type-R rear swaybar on a non-Type-R Integra. You may want to check on my Type-R rear swaybar installation instructions at http://www.geocities.com/bretq/swaybar_install.html if you are interested in installing the Type-R rear swaybar. You can also check out my mounting/reinforcement kit at http://www.geocities.com/bretq/mounting_kit.html .
