HELP PLEASE ASAP...another radiator question. DA for rex?(already searched)
Old Feb 19, 2006 | 07:56 AM
ef8powr91's Avatar
Default HELP PLEASE ASAP...another radiator question. DA for rex?(already searched)
Hello everyone. Last night my old radiator gave out on me so i need a new one ASAP so i can go to work and school. I have a '91 CRX si with a B16 and was currently runnig a stock radiator(which worked fine for 3 years until yesterday). I searched already and after reading that DA integra radiators fit and work better because of the thickness and/or dual core, i decided to buy one. My question is, what year DA do i buy the radiator for and can i bold up the stock fan to it?
heres a picture of a CRX with a DA radiator that i found on this site. IT looks like it fits well but i dont see the fan:
I know that i can use a stock radiator, but the DA radiator should work better because its thicker and made for a b-series right? I cant afford a really nice 300+ aluminum radiator so i need this to work so i can go to work tommorow. Autozone is currently holding this part for me and they close at 8pm central and its 11 am now. I need this tonight so if u guys could give me the best advice ASAP, i'd appreciate it. Thanks!
Old Feb 19, 2006 | 08:25 AM
charliev's Avatar
the radiator fan wont matter if you are doing a temperary fix until you can find out how to mount it or you could get a slimfan if seen um for like 55 bux shipped
Old Feb 19, 2006 | 08:28 AM
ef8powr91's Avatar
Default Re: (charliev)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charliev &raquo;</TD></TR><TR><TD CLASS="quote">the radiator fan wont matter if you are doing a temperary fix until you can find out how to mount it or you could get a slimfan if seen um for like 55 bux shipped</TD></TR></TABLE>
so theres no way to use the fan that i alrady have?
Old Feb 19, 2006 | 09:12 AM
fireant's Avatar
Default Re: (ef8powr91)
I was in the same position a month ago, and decided to find a new one instead of taking the risk of a used radiator failing on me catastrophically. The problem with buying a used radiator is that it will die out on you too someday, and you'll have to buy another.
Can you afford a $109 aluminum OE-spec radiator shipped?
http://www.radiatorworld.com/r...cat=1
That top one is made by Visteon. I got one and its very nice, perfect fit, uses stock fan, water temp stays lower now.
They have Visteon DA radiators too for $105 ( http://www.radiatorworld.com/r...cat=1 ), but the size is different:
DA Dimension: 12 13/16 x 25 7/8 x 1
CRX Dimension: 12 11/16 x 25 7/8 x 5/8
The width is right, so there's a chance the thicker, taller DA would fit, esp without an AC.
The CRX one will work with both types of OE fan.
Modified by fireant at 12:26 PM 2/19/2006
Old Feb 19, 2006 | 09:41 AM
ef8powr91's Avatar
Default Re: (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">I was in the same position a month ago, and decided to find a new one instead of taking the risk of a used radiator failing on me catastrophically. The problem with buying a used radiator is that it will die out on you too someday, and you'll have to buy another.
Modified by fireant at 12:26 PM 2/19/2006</TD></TR></TABLE>
thanks
Old Feb 19, 2006 | 11:51 AM
Crx Jimmy's Avatar
Default Re: HELP PLEASE ASAP...another radiator question. DA for rex?(already searched) (ef8powr91)
the stock main fan works with the da radiator, it will line up i needed to bend one of the plastic tabs about 1/8 inch to get it to line up but that was it, i dont know if the ac fan lines up i dont have ac
Old Feb 19, 2006 | 01:14 PM
crxtreme89h's Avatar
Default Re: HELP PLEASE ASAP...another radiator question. DA for rex?(already searched) (Crx Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">the stock main fan works with the da radiator, it will line up i needed to bend one of the plastic tabs about 1/8 inch to get it to line up but that was it, i dont know if the ac fan lines up i dont have ac
Holy Intake Girth!
Old Feb 19, 2006 | 02:48 PM
ef8powr91's Avatar
^^^ Thanks a lot guys. I already fixed my car and it runs very good The fan bolted right up to the DA radiator no problems and my car seems to pull a little harder as well. Thanks again for all the help!
-faded-
Feb 27, 2008 04:41 PM
95LSS
Jul 24, 2006 06:35 PM
FF-Greg
Jan 25, 2006 06:52 PM
SuicideSlide
Nov 26, 2004 08:53 AM
