Suspension & Brakes Theory, alignment, spring rates....
Ksport install question for EF
Old Feb 19, 2006 | 07:34 AM
Vtakkk's Avatar
Default Ksport install question for EF
Im about to install my ksports, the whole shock body is threaded, so how far should the lower mount go up ? ?
Old Feb 19, 2006 | 07:56 AM
PIC Performance's Avatar
Default Re: Ksport install question for EF (Stupid EF)
For ours, or anything of that design, we usually recommend no less an one inch and a half of shock body inside the lower mount to be safe. Make sure you get the locking collar very tight.
Old Feb 19, 2006 | 08:32 AM
Vtakkk's Avatar
Default Re: Ksport install question for EF (PIC Performance)
Is this going to measure how low my car is going to be, what would you recommend for the amount inside the shock body, im trying to get my car at a 2.5 drop
Old Feb 19, 2006 | 08:36 AM
For most applications, you'll have the car low enough that you should not have to worry about the minimum amount in. If you do find that the car is too low, and that you need to raise it, then keep an eye out for this minimum length.
Old Feb 19, 2006 | 08:39 AM
Vtakkk's Avatar
pm'n you
bmxtrev
Jan 24, 2012 03:10 PM
Dark Star
Feb 10, 2009 11:50 AM
KRZRICAN
Feb 5, 2009 10:17 PM
