What is a cheap/easy VTEC swap into CRX Si
Old Mar 27, 2002 | 05:08 PM
89 CRX SI's Avatar
Default What is a cheap/easy VTEC swap into CRX Si
Hey all well time to ask the experts again. Well i have a 89 CRX Si and I love the power it produces with minor bolt ons I would like a SOHC Vtec motor. Are they cheaper the a DOHC Vtec motor??? Well can you take like ets say a ZC engine and put VTEC on it?? I would like to know what are some engine swaps that are fairly plug and play and have VTEC. Also what RPM does VTEC engage at and can you change that RPM with a VTEC controller. THX again guys
PS: I want to go all motor
[Modified by 89 CRX SI, 2:09 AM 3/28/2002]
Old Mar 27, 2002 | 05:13 PM
EP3_05's Avatar
Default Re: What is a cheap/easy VTEC swap into CRX Si (89 CRX SI)
Either a mini-me swap or the full sohc Vtec swap would be the cheapest and easiest way to get Vtec in an 88-91 civic. The dohc zc will not accept a Vtec head without major work.
Old Mar 27, 2002 | 06:01 PM
89 CRX SI's Avatar
Default Re: What is a cheap/easy VTEC swap into CRX Si (91civic)
What is mini-me???? And does the SOHC VTEC require just the head or hole engine. presently i have a d16A6 What cars can these be found off of?
Old Mar 27, 2002 | 06:13 PM
4gvtec's Avatar
dont know if you got the email go here http://crx.honda-perf.org/articles/z6swap/z6swap.html
Old Mar 27, 2002 | 06:14 PM
EP3_05's Avatar
Mini-me is when you put a sohc vtec head onto a non-vtec block.
Old Mar 27, 2002 | 06:17 PM
89 CRX SI's Avatar
THX 4gvtec and 91 civic. Ill read that site etc. and ask some more questions etc. Very appreciative
Old Mar 27, 2002 | 06:20 PM
89 CRX SI's Avatar
So i guess once i find a 93ish civic with SOHC VTEC at a yard i can get all my parts off it. What about if your car isnt an Si. My buddy has a DX and we were going to do a MPFI swap this week. You still need to do that swap regardless if your going to go VTEC or not right>>>???? THX
Old Mar 27, 2002 | 06:22 PM
EP3_05's Avatar
Yep you always have to do the mpfi swap when using a motor other than one that runs dpfi. And the only one that I know that does are the 88-91 civic/crx dx and some of the crx hf's.
Old Mar 27, 2002 | 06:24 PM
89 CRX SI's Avatar
Can you buy a SOHC VTEC head at a online wrecker or something..? What is stock Compression ratios for these on CRX bottoms? Would it be worth it to shave head down a bit???
THX so mucha again
Old Mar 27, 2002 | 06:26 PM
EP3_05's Avatar
Where is jdmb18hatch when you need him??? He could probably tell you more about the compression ratios since he knows a lot about the sohc swaps and tech stuff.
[Modified by 91civic, 10:33 PM 3/27/2002]
Old Mar 27, 2002 | 06:32 PM
4gvtec's Avatar
go for the 96-00 y8 vtec head.on this year head the distrib bolts up perfect.on the 92-95 it needs some work done to the distrib since its only held on by to bolts insted of three.you can use the dx intake, but go with the si or mpfi.dx to si you need si ecu- si distrib-si intake throttle body fuel rail in ijectors-si resistor box or one from the integra-si throttle cable,and go to honda hybrid site for the wire diagram.also it helps to get a copy of a 1.5 and 1.6 diagram from a honda dealer to go with the other honda hybrid diagram.yes vtec or not change from dx to mpfi.
Old Mar 27, 2002 | 06:38 PM
4gvtec's Avatar
Default Re: What is a cheap/easy VTEC swap into CRX Si (4gvtec)
go here for the dx to si or zc-http://hybrid.honda-perf.org/tech/4gdxtozc.html
Old Mar 27, 2002 | 06:41 PM
89 CRX SI's Avatar
THX again 4gvtec..........
Old Mar 27, 2002 | 09:23 PM
sicivic's Avatar
The 92-95 D16Z6 head on a CRX block will yeild about 10.5:1 compression ratio and the 96-00 D16Y8 head on a CRX block will yield about 11:1 comp. ratio. Let me know if have any questions. I am running a mini-me in my car right now.
Old Mar 28, 2002 | 07:40 AM
EFSiR's Avatar
Default Re: What is a cheap/easy VTEC swap into CRX Si (sicivic)
if you decide to go with SOHC VTEC, check this for some help http://www.angelfire.com/ca/DrOhm/hybrid.html
WIth HASPORT better mounts (bolt in process now), I'd go for B16. Do it right the first time.
Old Mar 28, 2002 | 09:04 AM
CRX1770's Avatar
Default Re: What is a cheap/easy VTEC swap into CRX Si (EFSiR)
[/QUOTE]
make all the work worth it .... B16 is the best choice
kingofnothing
15
Sep 23, 2007 03:31 PM
btcca4
Aug 12, 2004 12:40 AM
1hotvtec
16
Jun 21, 2003 11:10 PM
jack
May 7, 2002 04:21 PM
