LS/VTEC What next?
Old Feb 18, 2006 | 10:44 PM
nangwalt's Avatar
Default LS/VTEC What next?
I have a LS/Vtec in my '95 Civic DX with a B18B bottom end, DC Sports Headers, Mugen chipped ECU, fuel regulator, AEM adjustable cam gears, and a test pipe. What do you think the is producing WHP? Also, what do you think I should next to produce the most power? If you can give me a list with the first thing you would do and so forth.
Old Feb 19, 2006 | 12:41 AM
nangwalt's Avatar
Default Re: LS/VTEC What next? (nangwalt)
bump
Old Feb 19, 2006 | 12:55 AM
Oyvind Ryeng's Avatar
Cams /v valvetrain, higher compression and tuning.
Old Feb 19, 2006 | 02:53 PM
Brick Top's Avatar
Default Re: LS/VTEC What next? (Oyvind Ryeng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oyvind Ryeng &raquo;</TD></TR><TR><TD CLASS="quote">Cams /v valvetrain, higher compression and tuning.</TD></TR></TABLE>
Old Feb 19, 2006 | 03:01 PM
LSVTEC 91 Civic's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nangwalt &raquo;</TD></TR><TR><TD CLASS="quote">I have a LS/Vtec in my '95 Civic DX with a B18B bottom end, DC Sports Headers, Mugen chipped ECU, fuel regulator, AEM adjustable cam gears, and a test pipe. What do you think the is producing WHP? Also, what do you think I should next to produce the most power? If you can give me a list with the first thing you would do and so forth.</TD></TR></TABLE>
I'm guessing you're rocking stock rod bolts? Hopefully you're keeping the LS rev limit.
I would upgrade your header to at least a JDM 4-1 with a 2.5" collector, or go with one of the better headers.
If you want to make power, you're going to need compression, headwork, cams, and tuning.
Search.
ImXposed
Feb 10, 2007 02:48 PM
ek9 ferio
10
Feb 16, 2006 07:59 PM
AZNracerx1989
Nov 27, 2005 08:01 PM
coronadrinker
Nov 22, 2005 09:17 AM
Carpediem291
Apr 9, 2002 01:17 PM
