Anyone Read, About my fuel pump problem
Old Feb 18, 2006 | 09:20 PM
rleonekc's Avatar
Default Anyone Read, About my fuel pump problem
Ok so just now i finally got my car started, and its blowing out thick white smoke... could that have something to do with the fuel pump?
Old Feb 18, 2006 | 09:28 PM
BLKFLSH's Avatar
Default Re: Anyone Read, About my fuel pump problem (rleonekc)
If it started, it's obviously getting fuel. Don't know what's causing the white smoke though, sorry.
Old Feb 19, 2006 | 06:10 AM
P_Adams's Avatar
Some steam from a cold exhaust system is normal first thing on a cold morning. But if you're talking about volumous clouds of thick acrid white smoke that doesn't go away; then you're looking at an internal coolant leak. Coolant is getting into the combustion chamber (not good).
This indicates:
1) Blown Head Gasket (survivable if addressed quickly)
2) Cracked Head or cracked cylinder liner (requires a more agressive approach)
Watch your coolant level
P
Old Feb 19, 2006 | 12:56 PM
YeuEmMaiMai's Avatar
head gasket failure will cause your car to blow thick white smoke. has your car ever been overheated?
Old Feb 19, 2006 | 08:22 PM
eagleclawracing's Avatar
Default Re: Anyone Read, About my fuel pump problem (YeuEmMaiMai)
Old Feb 19, 2006 | 08:53 PM
as_fast_as_u's Avatar
thick white smoke===coolant leak (BAD!!!!)...
Old Feb 20, 2006 | 05:29 AM
egriffith45's Avatar
Default Re: (as_fast_as_u)
if you think its a coolent leak, check your dipstick for the oil turning a creamy color. thats usually a good indication of coolant in the oil.
Old Feb 20, 2006 | 03:17 PM
Default Re: (egriffith45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egriffith45 &raquo;</TD></TR><TR><TD CLASS="quote">if you think its a coolent leak, check your dipstick for the oil turning a creamy color. thats usually a good indication of coolant in the oil.</TD></TR></TABLE>
If that has happened, go straight to rebuild instead of just repairing leak. When you get coolant in the oil, 99% of the time your main bearings get toasted or damaged and will fail within a short time.
project ak
Jul 28, 2006 03:00 AM
maivietla
Mar 27, 2005 10:57 AM
SIK IN DA HED
Oct 16, 2003 02:31 PM
CityHunt3r
Sep 30, 2003 05:07 AM
B18C-RnVA
Dec 9, 2001 08:09 PM
