Fuel pump
Old Feb 18, 2006 | 09:06 PM
rleonekc's Avatar
Default Fuel pump
So would a fuel pump be a issue for starting??
(if it was going bad, or is bad, ect)
-Rob
1990 Honda Accord EX
4 Door, AUTO
Old Feb 18, 2006 | 09:14 PM
Dmc1's Avatar
Default Re: Fuel pump (rleonekc)
Definitely it could keep a car from starting.A easy way to check it would be to have someone turn the key while you spray a little bit of starting fluid in the intake.If it starts and dies then it's a good sign your not getting enough fuel.
Old Feb 18, 2006 | 09:23 PM
BLKFLSH's Avatar
Could be. But you would have to check some things to be sure.
1. Power to the fuel pump (when ignition is turned on) for two seconds (main relay)
2. If #1 checks out ok, (fuel pump runs) fuel at fuel rail.
3. If #2 checks out ok, check for spark. (remove plug, with wire connected crank engine while looking for spark)
jthrasher1
Dec 11, 2010 12:45 PM
WavyIntegra
Jan 1, 2010 01:57 PM
project92ex
Oct 25, 2008 11:00 PM
Cameron60
Jan 16, 2007 06:04 PM
crexSIvtec
Mar 5, 2005 05:10 AM
