SOHC ZC ???
Old Feb 18, 2006 | 08:52 PM
migizzel's Avatar
Default SOHC ZC compresion ???
hey there i was just wondering what would be a good reading when you test the compresion on the sohc zc mine was
1- 180psi
2- 180psi
3- 175psi
4-180psi
just want to check if this is normal or not thanks
Modified by migizzel at 10:12 PM 2/18/2006
Old Feb 18, 2006 | 09:05 PM
migizzel's Avatar
Default Re: SOHC ZC ??? (migizzel)
bump somebody has to know this in here
Old Feb 18, 2006 | 09:14 PM
crxnj's Avatar
Thats normal..If it was like 180,180,180,60 Then you have a problem..
Old Feb 18, 2006 | 09:17 PM
migizzel's Avatar
Default Re: SOHC ZC ??? (Mr.speaker)
cool so a 5psi diffrence is not an issue???
Old Feb 18, 2006 | 09:21 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migizzel &raquo;</TD></TR><TR><TD CLASS="quote">cool so a 5psi diffrence is not an issue???</TD></TR></TABLE>
No not a problem at all..My old motor was 190,185,190,185 and it ran perfect and healthy..
Old Feb 18, 2006 | 09:29 PM
migizzel's Avatar
thanks man so now i need to find out why my car missing just a little
Old Feb 18, 2006 | 09:35 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migizzel &raquo;</TD></TR><TR><TD CLASS="quote">thanks man so now i need to find out why my car missing just a little</TD></TR></TABLE>
You tried replacing the cap,rotor and plugs already?
Old Feb 19, 2006 | 10:04 AM
migizzel's Avatar
i have brand new wires, cap, rotor as well as a new obx intake manifold and a b16 tb and i don't have hi rpm power
Old Feb 19, 2006 | 10:07 AM
boostinaintez's Avatar
Looks good to me.
Old Feb 19, 2006 | 10:11 AM
xaine's Avatar
the service manuels ussually say it can be within about 20 psi from specs
Old Feb 19, 2006 | 10:21 AM
davens's Avatar
Default Re: SOHC ZC ??? (xaine)
Um...that's incorrect.
Normal Nompression is 180psi
Minimal Compression is 135psi
Maximum Variance is 28psi
Old Feb 19, 2006 | 10:24 AM
migizzel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xaine &raquo;</TD></TR><TR><TD CLASS="quote">the service manuels ussually say it can be within about 20 psi from specs</TD></TR></TABLE>
so what are the specs??
xaine's Avatar
Default Re: SOHC ZC ??? (davens)
i said ABOUT 20 from spec
it says 28 varience
so i was off 8psi
my bad
Old Feb 19, 2006 | 10:25 AM
Phrost's Avatar
this is true there can be up to 20 psi in difference between the cylinders, also have you advanced the timing or retarded it maybe that would work..
Old Feb 19, 2006 | 10:40 AM
Bjorn20's Avatar
hmm, my d15 motor was like
180
170
160
155
Old Feb 19, 2006 | 11:10 AM
davens's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">ussually say it can be within about 20 psi from specs</TD></TR></TABLE>
That sounds like as long as its within a 20 psi difference from spec, its okay.
So taking your answer literally, if spec is 180 and you get:
150, 155, 150, 150 on all four cylinders - its out of spec (since they are all more than 20 psi below spec)
200, 160, 160, 200 - its within spec (since each cylinder is within 20 psi of 180)
...both of which we know is not the case.
So even if we overlook the inaccurate variance quote, there's still the murky answer.
I don't doubt you knew what you were talking about...you just need to be more clear when you're answering peoples questions (or don't bother).
square_1
20
Dec 4, 2006 04:59 PM
the king.
Sep 26, 2006 12:32 PM
evil_ryu
Mar 12, 2006 05:07 PM
farmboy777
12
Jan 19, 2006 08:26 AM
fbapacible6
Sep 5, 2004 12:43 PM
