Pro Honda Dot 4 Brake Fluid
http://www.ronayers.com/catalo...=1261
I found a few bottles of this today for $.50 a bottle, would it be safe to use this for my cars brakes? It is dot 4 and heavy-duty/high-temp and figured it would be a little better for autocross with the higher boiling point of 490+ degrees dry and 311 minimum wet. But I think it is mainly made for motorcycles and stuff for that so that is why I am asking. TIA
It'd probably work out "fair". Pretty much ever other fluid that one would consider is better, even valvoline synpower.
ARRANGED BY DRY BOILING POINT:
DRY:527F -- WET:302F --- AP RACING 551 ($12.95/0.5L OR 16.9 OZ)
DRY:527F -- WET:347F --- VALVOLINE SYNPOWER DOT3 & DOT4
DRY:536F -- WET:392F --- ATE SUPERBLUE/TYP200 ($9.95/1L)
DRY:550F -- WET:284F --- FORD HEAVY DUTY DOT 3 ($4/12 OZ)
DRY:570F -- WET:284F --- WILWOOD 570 ($5.65/12 OZ)
DRY:570F -- WET:284F --- PERFORMANCE Friction Z rated ($6.27/16 OZ)
DRY:590F -- WET:410F --- AP RACING 600 ($16.95/0.5L OR 16.9 OZ)
DRY:590F -- WET:518F --- CASTROL SRF ($69.00/1L 0R 33.8 OZ)
DRY:593F -- WET:420F --- MOTUL RBF600 ($12.95/0.5L OR 16.9 OZ)
DRY:601F -- WET:399F --- BREMBO LCF 600 PLUS ($26.75/0.5L OR 16.9 OZ)
DRY:608F -- WET:390F --- AP RACING 660 ($-/0.5L OR 16.9 OZ)
DRY:610F -- WET:421F --- NEO SYNTHETICS SUPER DOT 610 ($11.95/12 OZ)
DRY:610F -- WET:421F --- PROSPEED GS610 ($39.95/16 OZ)
DRY:626F -- WET:417F --- WILWOOD EXP 600 ($16.95/0.5L 16.9 OZ)
I have never used the fluid you are talking about, but I have used the Valvoline Synpower and had problems with it boiling. Pretty bad. I switched to the ATE expecting the same problems, but have yet to see it boil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant »</TD></TR><TR><TD CLASS="quote">Any reason not to run something like NEO SYNTHETICS SUPER DOT 610 in a stock honda system?</TD></TR></TABLE>
Nope, no reason at all.
It may be somewhat hard to find, though. Motul RBF 600 is sold in lots of speed shops.
descartesfool
Aug 18, 2013 01:09 PM
