installed Pro 1s and car does want to start
Old Feb 18, 2006 | 03:44 PM
GSRfoedoe's Avatar
Default installed Pro 1s and car does want to start
motor is a gsr with p73 pistons head is milled 30thousandths. jun valve train and the cam gears are set to 0,0. the valve clearance are .007intake and .008 exhaust and timing in right on point. i can get it to start and keep idiol if i advance both cams to +1 then it shuts off. the fuel pressure is right around 40 with vaccum hose off. im running it off a chipped p28 from kenji
Old Feb 18, 2006 | 03:56 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: installed Pro 1s and car does want to start (GSRfoedoe)
remove about 25% fuel at idle, open up you idle screw a bit and readjust the tps sensor and try 25-26 degres of timing and it should idle fairly well. These cams are not a drop in and go if you dont know what your doing. Donf can give you some excelent pointers as well. You will alsu have to advance your cam gears a little more due to the milling of the head. Did you clay for valve to piston clearance?
Old Feb 20, 2006 | 06:13 AM
GSRfoedoe's Avatar
Default Re: installed Pro 1s and car does want to start (PURPLETERROR aka BIGMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">remove about 25% fuel at idle, open up you idle screw a bit and readjust the tps sensor and try 25-26 degres of timing and it should idle fairly well. These cams are not a drop in and go if you dont know what your doing. Donf can give you some excelent pointers as well. You will alsu have to advance your cam gears a little more due to the milling of the head. Did you clay for valve to piston clearance? </TD></TR></TABLE>
yes i did clay the motor. is there a way i can get a chipped program for these cams so i can atleast drive it to the dyno.
Old Feb 20, 2006 | 12:23 PM
VtecKiDD's Avatar
the cam gears need to be adjusted because the head has been milled that much. i forget what the number is exactly, but i think for ever .013 thou, you move the gear +1.
someone correct me if i am wrong. thats probably the problem Dyno. Try that, and put a stock ecu in it, until it runs.
Dyno, PM JOHNZM on this board, or call me at the shop, i have Pro1 maps i can get to you
Old Feb 20, 2006 | 12:52 PM
92TypeR's Avatar
FSAE
Default Re: installed Pro 1s and car does want to start (VtecKiDD)
IIRC, 30 thousandths = ~1degree
There is an alan key adjuster for the throttle plate, open it up slightly and tune for about 15:1 AF at idle. Should purr like a kitten.
Old Feb 21, 2006 | 12:47 PM
johnzm's Avatar
Default Re: installed Pro 1s and car does want to start (92TypeR)
dude i can help you out man.
i am sick as **** at the moment. if u can bring me a chip, TO me i can get you a proper map. FYI i ran the pro1's in my GSR as well, so i have extensive tuning experience with them, and a bunch of basemaps to start you on.
also tuning if you wanna do it. just gimme a couple days to get better.
Old Feb 21, 2006 | 01:37 PM
vtecmissle's Avatar
Default Re: installed Pro 1s and car does want to start (johnzm)
i need a basemap for a hondata s300 do youi know where i can get one. I have a b18c1 with a diy ported head. Os valves and a diy ported aebs manifold. Just need something to get me started before i dyno.
Old Feb 21, 2006 | 02:12 PM
ITRnorway's Avatar
should he advance both camgears 1degree?
Old Feb 21, 2006 | 02:23 PM
DonF's Avatar
Default Re: (CRXnorway)
He needs to call the Skunk dealer he bought them from and get advice.
Old Feb 21, 2006 | 02:36 PM
jax si's Avatar
Default Re: (DonF)
gas, grass, or *** ... nobody rides for free $ $
Old Feb 21, 2006 | 04:18 PM
GSRfoedoe's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">He needs to call the Skunk dealer he bought them from and get advice.</TD></TR></TABLE>
i called Skunk and they are tellin me to get it tune....i just to be able to drive to get it tuned. i know its not goin to be perfect, i got Vteckidd to get me a Pro1 program so it should make it up to his shop
quick99gs-r
May 25, 2009 06:35 AM
GSR_96814
Sep 19, 2006 01:44 PM
matix
Sep 6, 2005 09:10 AM
VTEC Visions
49
Sep 3, 2005 11:19 PM
LOWNSLOW
May 24, 2004 08:54 AM
