searched with no luck, b18c5 head on b20 block
Old Feb 18, 2006 | 03:02 PM
XiOus271's Avatar
Default searched with no luck, b18c5 head on b20 block
ok, im looking on ebay and i found an ITR and in the description said the engine was a b18 head on a b20 block. i am an accord driver right now, so i figured id be better asking all of you ITR drivers for advice. ive seen plenty of stuff about b16 heads on b20 blocks, so i wanted to see if this an actual possible swap, and if so what kind of power would it make, how reliable would it be, do i need to worry about revving higher without having to worry about the crank killing itself (dont know much b20 rev limits), etc...? if this has been answered in another post that i couldnt find, could you please let me know? thanks in advance.
Modified by XiOus271 at 6:35 PM 2/18/2006
Old Feb 18, 2006 | 03:42 PM
Yoinked's Avatar
Default Re: searched with no luck, b18c5 head on b20 block (XiOus271)
The only difference between a Type R head and a B16 head is porting, valve springs and cams.
Old Feb 18, 2006 | 03:46 PM
XiOus271's Avatar
Default Re: searched with no luck, b18c5 head on b20 block (negtegra.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by negtegra. &raquo;</TD></TR><TR><TD CLASS="quote">The only difference between a Type R head and a B16 head is porting, valve springs and cams. </TD></TR></TABLE>
ok so im sure that it will work. do you know anything about the reliability and power?
Old Feb 18, 2006 | 04:56 PM
nightrider's Avatar
check out marshall's 2.0 litre.
https://honda-tech.com/zerothread?id=1531146
ALLmotor_89
26
Mar 26, 2010 01:27 AM
herk_1
Oct 29, 2008 10:35 AM
b18hondahb
Oct 26, 2006 05:55 AM
OEMRedEG
Feb 17, 2004 01:08 PM
