stock acura cd player HELP
Old Feb 18, 2006 | 07:27 AM
terribl3jon's Avatar
Default stock acura cd player HELP
I got an acura cd player from my friend and i put the code in. It will load a cd but it won't play or maybe im just not getting volume, I can skip tracks. As for the radio i can change stations but I get no volume.
anyone had this problem?
Old Feb 18, 2006 | 08:10 AM
fcm's Avatar
fcm
Old Fart
Default Re: stock acura cd player HELP (terribl3jon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by terribl3jon &raquo;</TD></TR><TR><TD CLASS="quote">I got an acura cd player from my friend and i put the code in. It will load a cd but it won't play or maybe im just not getting volume, I can skip tracks. As for the radio i can change stations but I get no volume.
anyone had this problem?</TD></TR></TABLE> I can only assume you have a 94 or newer Integra, [gsr teg&lt;3] My info is good for 94-98 Integras....
If the fuses are good, fuse 47 - 7.5A, [constant power] in under hood fuse box and fuse 28 - 10A, [acc. power] in under dash fuse box, and there is no short in the speakers or the speaker wiring, the HU is N/G, probably blown outputs.
You will need a multimeter to check for short in speaker system 94
Old Feb 18, 2006 | 09:56 AM
Default Re: stock acura cd player HELP (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> I can only assume you have a 94 or newer Integra, [gsr teg&lt;3] My info is good for 94-98 Integras....
You will need a multimeter to check for short in speaker system 94</TD></TR></TABLE>
it works with my other cd player so im guessing these outputs you are talking about are blown on the unit. can i fix the outputs or am i beat?
Old Feb 18, 2006 | 09:59 AM
B18C_EJ8's Avatar
You could have the unit repaired, but a shop will probably charge upwards of $75 for the fix. Can probably find one on eBay for less..
Old Feb 18, 2006 | 06:09 PM
Default Re: (B18C_EJ8)
SOB! lol
immrtaltchnq
Audio / Security / Video
Jul 18, 2009 10:01 PM
simplegreenmachine
Aug 17, 2007 07:42 AM
GraphiteMW
Jul 14, 2007 07:32 AM
vandersmissenc
Sep 11, 2005 09:20 PM
Greenery18
Aug 31, 2004 10:05 AM
