Removing paint from plastic
Old Feb 18, 2006 | 07:08 AM
dkny_stylez's Avatar
Default Removing paint from plastic
So I bought the 99+ grill, but it's painted silver and I want to return it back to its original color. (black)
How would I go about doiung so?
Old Feb 18, 2006 | 07:18 AM
The_Sober's Avatar
Default Re: Removing paint from plastic (dkny_stylez)
paint it black
Old Feb 18, 2006 | 07:35 AM
uneek4dr's Avatar
what kind of spray paint?
Old Feb 18, 2006 | 07:36 AM
Hawkze_2.3's Avatar
Yeah, just lightly de-gloss the paint and paint it black. Don't even try to take paint off of plastic if it's on there good.
Old Feb 18, 2006 | 07:44 AM
how would you go about de-glossing it? And wouldn't a painted grill be more prone to chipping from rock chips etc?
Old Feb 18, 2006 | 07:48 AM
The_Sober's Avatar
Default Re: (dkny_stylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkny_stylez &raquo;</TD></TR><TR><TD CLASS="quote">what kind of spray paint?</TD></TR></TABLE>
are you shitting me?
Old Feb 18, 2006 | 07:52 AM
Default Re: (The_Sober)
hey man, there's all kinds of different sprays out there
Old Feb 18, 2006 | 08:00 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkny_stylez &raquo;</TD></TR><TR><TD CLASS="quote">how would you go about de-glossing it? And wouldn't a painted grill be more prone to chipping from rock chips etc?</TD></TR></TABLE>
Fine sand paper like 300 or so and just sand it until the shine is gone. Then just buy whatever paint you want and put on 2-3 thin coats.
Old Feb 18, 2006 | 08:55 AM
The_Sober's Avatar
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkny_stylez &raquo;</TD></TR><TR><TD CLASS="quote">hey man, there's all kinds of different sprays out there </TD></TR></TABLE>
true enough. didn't mean to fly off. keep in mind, though, that if you rattle-can it, it will never match the rest of the car exactly.
if you do spray it, then make sure you sand the paint really well, primer it, then paint it. Once you've put the color on that you want, scuff it with, like, 5000 grit or some other obscenely fine sandpaper. Then get a buffing wheel and some polishing compound and put a nice, high gloss on it.
roller3804's Avatar
sand it with really find grit. Then apply two coats of selfetching primer and then paint it. It will last longer and look cleaner that way.
Old Feb 18, 2006 | 12:35 PM
hmmm i'm thinking it's going to be too shiny, so the after I paint..A fine sand(1500) afterwards should make it look a bit dull to match the car?
Old Feb 19, 2006 | 11:27 AM
gospeedracerh23's Avatar
you only wetsand it if there is clear on there.. sand it by hand with 400 or 500 or 600 grit and then paint it flat black or gloss black or semi gloss or whatever you want, then your done.. no need for primer or anything.. no need for clear, unless you wanted it to match factory black paint but in that case it never would with spray can paint.
Jay J
Paint and Body
Sep 10, 2007 08:49 AM
Smallpox33
May 15, 2007 08:15 PM
JamesV
Jun 5, 2006 08:10 PM
SPORT INJECTION
May 29, 2005 11:15 PM
WHiTETYPEs
Feb 20, 2005 10:34 PM
