Vibration under acceleration - new mounts?
My car vibrates under acceleration but it drives smooth when I'm driving normal. How should I fix the problem?
1) Alignment?
2) Motor mount inserts?
3) Four new motor mounts?
4) New tires?
1) Alignment?
4) New tires?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ »</TD></TR><TR><TD CLASS="quote">I would find out what the problem is. And if it is indeed your mounts, go with new mounts..forget inserts.</TD></TR></TABLE>
man i need to find my self a motor mount kit as well
i was leaning forward to jimfeb or something but i know it's gone now
is there any other choice? without spending alot of money?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr1244 »</TD></TR><TR><TD CLASS="quote">
FYI (original post) there are 5 mounts, two side, one rear and two front lower 'torque mounts'.
Theres Jimfab (who I heard is working on other stuff now?), Hasport (for the two side and rear mounts), Mugen (makes the full kit of 5) and some other brands as well.
If you're looking to get a little more bang for your buck and the mounts arent cracked really bad you could do the good old 3M Window Weld for the OE mounts, I have the mugen mount kit, but also decided to add a little window weld (run a search)
HondaNerd
Jun 20, 2005 07:40 PM
kenethcole411
May 14, 2003 12:05 PM
