Tryin to reach 180whp.
Old Feb 17, 2006 | 10:32 PM
hotdoggies's Avatar
Default Tryin to reach 180whp.
Alright guys iam tryin to reach my goal of 180 whp on a b-16. My mods are in sig. She recently put down 167 whp with a bad cap/rotor. It has a stock intake mani and a shitty dc 4-2-1. I ave been lookiat the replica jdm type r headers like megan and a aebs i/m. Could i reach my goal with these????
Old Feb 17, 2006 | 11:17 PM
Carbonyl's Avatar
Default Re: Tryin to reach 180whp. (hotdoggies)
stage 2 cams since your compression is like 11.7 + better IM + better header will probably get you to 180 easy
Old Feb 17, 2006 | 11:20 PM
hotdoggies's Avatar
Default Re: Tryin to reach 180whp. (Carbonyl)
Iam tryin to do it without cams for now just tryin to get close at least 175.
Old Feb 18, 2006 | 07:02 AM
Phatch99's Avatar
what r u using to tune? maybe just a better header n IM will get you there or pretty close to 175whp
Old Feb 18, 2006 | 07:14 AM
adqnnlude's Avatar
Get a new tuning program, that silly vafc can't control timing and with the compression you are running that isn't a smart move. As far as 180, I would upgrade to a more aggressive cam with your compression to hit 180whp.
Old Feb 18, 2006 | 08:48 AM
mekanism's Avatar
Default Re: (adqnnlude)
Whatever you do dont buy that POS megan header. It hangs 2 inches below the pan. I had mine on for less than a week and destroyed it!
Old Feb 18, 2006 | 09:08 AM
kaoss_11's Avatar
B A N N E D
A great header is where your power will be made the most. I an aebs im will be good and crome. I think you will get that 180 you are looking for but its all in the header. I would go as far as a bigger tb maybe.
Old Feb 18, 2006 | 09:15 AM
hotdoggies's Avatar
Default Re: Tryin to reach 180whp. (kaoss_11)
I have a itr throttle body, and thanx for the comments guys keep'em comin. So the vafc must go? Decided not to buy megan header after i heard they have thin metal on the tubing.Looking at the jdm dc 4-1 now.
Old Feb 18, 2006 | 11:38 AM
hotdoggies's Avatar
The dc 4-1 jdm style header Would this suffice until i could get my hands on a hytech or sms?
Old Feb 18, 2006 | 04:41 PM
JerseySiPOS's Avatar
what are you revving 3rd gear to?? if it's 9000 max, keep your b16 intake manifold, you'll make more area with that. just get a type-r throttle body and bore your intake manifold to 62mm.
go with a 3" exhaust and a 2.25" collector. im just saving you money, because if you wanna use a type-r manifold, you'll have to spin it to about 9500 but the same hp, but you won't make any more speed because of the lower flatter tq curve. and forget about the AEBS manifold, way too big IMO.
SAE corrected, i made 171@8200 and about 118 tq from 6000-7500 rpms, but my header was a 4-1 with a 2.5" collector. that's too big, so there was more power to find in the same rpm range. something with a 2.25" collector that steps out to 3" will give you the best results.
....unless you like peak numbers only...
Old Feb 18, 2006 | 05:01 PM
ABK's Avatar
ABK
Default Re: Tryin to reach 180whp. (JerseySiPOS)
bigger and better header, change the IM, hondata (or uberdata, chrome whatever) instead of afc.
That should hit it.
Bigger cams will work better on your motor too. 2.5" exhaust will help to. Sounds like a strong motor. possibly could hit 185-190whp
Old Feb 18, 2006 | 06:28 PM
hotdoggies's Avatar
Default Re: Tryin to reach 180whp. (ABK)
I have a dyno sheet. Post up in a few min.
Old Feb 18, 2006 | 06:30 PM
hotdoggies's Avatar
Here is the dyno sheet. What do ya think about the i/m. Also shifting at stock redline.
Old Feb 18, 2006 | 06:52 PM
ABK's Avatar
ABK
defently get a new matifold (skunk2 or AEBS) should pick up prolly another 5 hp. Changing the header will help alot too.
Could also try to run a velocity stack intake, people seem to gain nice numbers from it.
Old Feb 18, 2006 | 07:01 PM
hotdoggies's Avatar
Also for the midrange lookin at cam gears. Worth it?
Old Feb 18, 2006 | 07:06 PM
b19coupe's Avatar
Your A/F is not great, a few ponies to be had just with better tuning.
Old Feb 18, 2006 | 07:23 PM
hotdoggies's Avatar
Default Re: Tryin to reach 180whp. (b19coupe)
Yea i noticed that also. I think he was tuning conservatively. So a new manifold has just been ordered today. Still thinkin about the header though. Any input?
Old Feb 18, 2006 | 07:30 PM
b19coupe's Avatar
Hytech, DTR, RMF, SMSP.
SMSP would be my first choice.
Old Feb 18, 2006 | 07:39 PM
hotdoggies's Avatar
Lookin at those but in the meantime was lookin more toward the jdm 4-1 dc header
Old Feb 18, 2006 | 08:06 PM
ABK's Avatar
ABK
Try to run that thing open header prolly another 2-3 hp in it.
I love AN-R header. I wonna get one so bad.
Old Feb 18, 2006 | 08:17 PM
dc2gsr96's Avatar
were is a good place to get those hearders from?
Old Feb 18, 2006 | 08:18 PM
ABK's Avatar
ABK
Default Re: Tryin to reach 180whp. (dc2gsr96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2gsr96 &raquo;</TD></TR><TR><TD CLASS="quote">were is a good place to get those hearders from?</TD></TR></TABLE>
which header???
Old Feb 19, 2006 | 02:32 PM
dc2gsr96's Avatar
any of these 4
Old Feb 19, 2006 | 08:09 PM
GetawayInMoscow's Avatar
did you notice any diff with the ITR TB?
Old Feb 19, 2006 | 08:32 PM
hotdoggies's Avatar
Default Re: Tryin to reach 180whp. (GetawayInMoscow)
There was a noticable increase in the sound, also it felt as if the car ran a lil better in between 6000 and 7000 rpm. Could be do to the fact that i was runnin rich at the time.
